跳转到主内容
Razer Blade Stealth 2016 Hard Drive Replacement
你所需要的
  1. Razer Blade Stealth 2016 Hard Drive Replacement, Hard Drive: 步骤 1 中的图像 1,1
    • Turn the laptop upside down!
  2. Razer Blade Stealth 2016 Hard Drive Replacement: 步骤 2 中的图像 1,1
    • There are 10 screws in total, they can be found at the red circles shown in the picture!
    • NOTE : you need to use a T5 screwdriver!
  3. Razer Blade Stealth 2016 Hard Drive Replacement: 步骤 3 中的图像 1,1
    • The hard drive is located under the fan on the left side as shown in the picture!
  4. Razer Blade Stealth 2016 Hard Drive Replacement: 步骤 4 中的图像 1,1
    • The hard drive is located under the fan on the left side.
    • Slowly peel back the silver piece and black tape beneath it to reveal the hard drive.
  5. Razer Blade Stealth 2016 Hard Drive Replacement: 步骤 5 中的图像 1,2 Razer Blade Stealth 2016 Hard Drive Replacement: 步骤 5 中的图像 2,2
    • Using a Phillips screwdriver, remove the 2.5 mm screw on the left side of the hard drive.
    • After you unscrew the hard drive, it will pop out by itself
    • The Phillips screw driver is included in the kit that was provided on step 2!
  6. Razer Blade Stealth 2016 Hard Drive Replacement: 步骤 6 中的图像 1,2 Razer Blade Stealth 2016 Hard Drive Replacement: 步骤 6 中的图像 2,2
    • Carefully slide the hard drive out from its slot.
结论
另外一个人完成了本指南。
Lindsay Grant
于10/10/19注册
403 声望
创作了3篇指南
团队
USF Tampa, Team S1-G4, Leahy Fall 2019 USF Tampa, Team S1-G4, Leahy Fall 2019 的会员
USFT-LEAHY-F19S1G4
4 名成员
创作了5篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 5
过去 30 天: 53
总计 2,498
