跳转到主内容
Razer Blade RZ09-0130 2015 Trackpad Button Replacement
你所需要的
  1. Razer Blade RZ09-0130 2015 Trackpad Button Replacement, Back Panel: 步骤 1 中的图像 1,2 Razer Blade RZ09-0130 2015 Trackpad Button Replacement, Back Panel: 步骤 1 中的图像 2,2
    • Be sure to power off the device before beginning.
    • Use a Torx T5 screwdriver to remove the ten 3 mm screws along the edge of the back panel.
  2. Razer Blade RZ09-0130 2015 Trackpad Button Replacement: 步骤 2 中的图像 1,2 Razer Blade RZ09-0130 2015 Trackpad Button Replacement: 步骤 2 中的图像 2,2
    • Remove the back panel from the laptop by sliding it away from the hinge.
    • This device is missing the battery. Make sure to detach the battery connector before proceeding with laptop repairs.
  3. Razer Blade RZ09-0130 2015 Trackpad Button Replacement, Trackpad Button: 步骤 3 中的图像 1,3 Razer Blade RZ09-0130 2015 Trackpad Button Replacement, Trackpad Button: 步骤 3 中的图像 2,3 Razer Blade RZ09-0130 2015 Trackpad Button Replacement, Trackpad Button: 步骤 3 中的图像 3,3
    • Detach the two connectors from the motherboard by gently pulling them directly out of their ports with your fingers.
  4. Razer Blade RZ09-0130 2015 Trackpad Button Replacement: 步骤 4 中的图像 1,2 Razer Blade RZ09-0130 2015 Trackpad Button Replacement: 步骤 4 中的图像 2,2
    • Use a Phillips #1 screwdriver to remove the two 3 mm screws holding the trackpad's circuit board to the chassis.
  5. Razer Blade RZ09-0130 2015 Trackpad Button Replacement: 步骤 5 中的图像 1,1
    • Remove the trackpad circuit board by holding one end and gently lifting it upwards.
结论
Carson Kellerman
于01/29/20注册
495 声望
创作了4篇指南
团队
Cal Poly, Team S18-G1, White Winter 2020 Cal Poly, Team S18-G1, White Winter 2020 的会员
CPSU-WHITE-W20S18G1
4 名成员
创作了6篇指南
一条评论
Looking for that small ribbon cable, very hard to find, any clues?
serpentexotics - 回复
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 6
总计 2,203
