跳转到主内容
Razer Blade RZ09-0130 2015 Fan Replacement
你所需要的
  1. Razer Blade RZ09-0130 2015 Fan Replacement, Back Panel: 步骤 1 中的图像 1,2 Razer Blade RZ09-0130 2015 Fan Replacement, Back Panel: 步骤 1 中的图像 2,2
    • Be sure to power off the device before beginning.
    • Use a Torx T5 screwdriver to remove the ten 3 mm screws along the edge of the back panel.
  2. Razer Blade RZ09-0130 2015 Fan Replacement: 步骤 2 中的图像 1,2 Razer Blade RZ09-0130 2015 Fan Replacement: 步骤 2 中的图像 2,2
    • Remove the back panel from the laptop by sliding it away from the hinge.
    • This device is missing the battery. Make sure to detach the battery connector before proceeding with laptop repairs.
  3. Razer Blade RZ09-0130 2015 Fan Replacement, Fan: 步骤 3 中的图像 1,2 Razer Blade RZ09-0130 2015 Fan Replacement, Fan: 步骤 3 中的图像 2,2
    • Remove the three screw caps by pulling them upward with your fingers.
  4. Razer Blade RZ09-0130 2015 Fan Replacement: 步骤 4 中的图像 1,1
    • Remove the three 3mm Phillips #0 screws.
  5. Razer Blade RZ09-0130 2015 Fan Replacement: 步骤 5 中的图像 1,2 Razer Blade RZ09-0130 2015 Fan Replacement: 步骤 5 中的图像 2,2
    • Peel back the two adhesive strips from the fan until they are removed.
  6. Razer Blade RZ09-0130 2015 Fan Replacement: 步骤 6 中的图像 1,3 Razer Blade RZ09-0130 2015 Fan Replacement: 步骤 6 中的图像 2,3 Razer Blade RZ09-0130 2015 Fan Replacement: 步骤 6 中的图像 3,3
    • Remove the connector by pulling it away from the motherboard with your fingers.
  7. Razer Blade RZ09-0130 2015 Fan Replacement: 步骤 7 中的图像 1,1
    • Holding the rounded edge of the fan, slowly lift upwards until it is removed.
  8. Razer Blade RZ09-0130 2015 Fan Replacement: 步骤 8 中的图像 1,1
    • Repeat the preceding steps to remove the second fan.
结论
Tyler Clayton
于01/22/20注册
183 声望
撰写一个指南
团队
Cal Poly, Team S18-G1, White Winter 2020 Cal Poly, Team S18-G1, White Winter 2020 的会员
CPSU-WHITE-W20S18G1
4 名成员
创作了6篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 4
过去 30 天: 11
总计 605
