跳转到主内容
Razer Blade RZ09-0130 2015 Display Replacement
你所需要的
  1. Razer Blade RZ09-0130 2015 Display Replacement, Back Panel: 步骤 1 中的图像 1,2 Razer Blade RZ09-0130 2015 Display Replacement, Back Panel: 步骤 1 中的图像 2,2
    • Be sure to power off the device before beginning.
    • Use a Torx T5 screwdriver to remove the ten 3 mm screws along the edge of the back panel.
  2. Razer Blade RZ09-0130 2015 Display Replacement: 步骤 2 中的图像 1,2 Razer Blade RZ09-0130 2015 Display Replacement: 步骤 2 中的图像 2,2
    • Remove the back panel from the laptop by sliding it away from the hinge.
    • This device is missing the battery. Make sure to detach the battery connector before proceeding with laptop repairs.
  3. Razer Blade RZ09-0130 2015 Display Replacement, Display: 步骤 3 中的图像 1,1
    • Remove the two 5mm Phillips #00 screws.
  4. Razer Blade RZ09-0130 2015 Display Replacement: 步骤 4 中的图像 1,1
    • Remove the plastic panel.
  5. Razer Blade RZ09-0130 2015 Display Replacement: 步骤 5 中的图像 1,1
    • Remove one 3mm Phillips #00 screw from the metal plate.
  6. Razer Blade RZ09-0130 2015 Display Replacement: 步骤 6 中的图像 1,1
    • Repeat the previous three steps on the opposing side.
  7. Razer Blade RZ09-0130 2015 Display Replacement: 步骤 7 中的图像 1,1
    • Gently open the device with your hands and separate the display from the keyboard.
    • The device will make a popping or cracking sound when the two pieces separate. This is normal.
结论
Ben Haering
于01/29/20注册
121 声望
撰写一个指南
团队
Cal Poly, Team S18-G1, White Winter 2020 Cal Poly, Team S18-G1, White Winter 2020 的会员
CPSU-WHITE-W20S18G1
4 名成员
创作了6篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 10
总计 748
