跳转到主内容
简介
Over time, lithium-ion batteries inevitably degrade, dramatically reducing their lifespan. The higher operating temperatures in gaming laptops speeds up their degradation; if you've been using your Razer Blade RZ09-0130 2015 for more than a couple years, and the battery life is either very short, or it can't even run while unplugged, it's definitely time for a replacement.
Before beginning these guide, make sure that the system is shut down, unplugged, and that there is no static build up on your person.
If you find your battery is swollen, take extreme caution in removal, and dispose of your battery through the proper channels.
配件
没有特定配件。
  1. Razer Blade RZ09-0130 2015 Battery Replacement, Back Panel: 步骤 1 中的图像 1,2 Razer Blade RZ09-0130 2015 Battery Replacement, Back Panel: 步骤 1 中的图像 2,2
    • Be sure to power off the device before beginning.
    • Use a Torx T5 screwdriver to remove the ten 3 mm screws along the edge of the back panel.
  2. Razer Blade RZ09-0130 2015 Battery Replacement: 步骤 2 中的图像 1,2 Razer Blade RZ09-0130 2015 Battery Replacement: 步骤 2 中的图像 2,2
    • Remove the back panel from the laptop by sliding it away from the hinge.
    • This device is missing the battery. Make sure to detach the battery connector before proceeding with laptop repairs.
  3. Razer Blade RZ09-0130 2015 Battery Replacement, Battery: 步骤 3 中的图像 1,1
    • Detach the battery's ribbon cable from the motherboard.
  4. Razer Blade RZ09-0130 2015 Battery Replacement: 步骤 4 中的图像 1,1
    • Use a Phillips #0 screwdriver to remove the six 3 mm screws securing the battery.
    • Lift the battery up and out.
结论
0条评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 2
过去 30 天: 42
总计 312
