跳转到主内容
Razer Blade 15 Keyboard Replacement
你所需要的
  1. Razer Blade 15 Keyboard Replacement, Remove the Back Cover: 步骤 1 中的图像 1,1
    • Flip over to the back side of the laptop
    • Remove the 10 screws at the bottom of the Razer using a T5 screwdriver head
  2. Razer Blade 15 Keyboard Replacement, Remove the Laptop Battery: 步骤 2 中的图像 1,1
    • Unplug the battery and wear the anti-static band before proceeding
    • Unscrew the six Philips screws around the battery and lift the battery
  3. Razer Blade 15 Keyboard Replacement, Remove the SSD: 步骤 3 中的图像 1,1
    • Find the SSD and unscrew the single screw
    • Once it is unscrewed, the SSD will pop up on one side
    • Carefully remove the SSD and place it to the side
  4. Razer Blade 15 Keyboard Replacement, Disconnect the MOBO Cables: 步骤 4 中的图像 1,1
    • Locate the two display cables to the left of the left speaker and disconnect both. (one is underneath the other)
    • Locate and disconnect the four cables
    • Disconnect one cable that is underneath the SSD
    • Disconnect another cable that is next to the right fan
    • Disconnect the final two cables that are to the left of the battery connector
  5. Razer Blade 15 Keyboard Replacement, Remove the Fans and Speakers: 步骤 5 中的图像 1,1
    • Unscrew the four screws on the fans (two screws on each)
    • Make sure to unplug the connector on each of the fans. Lift and remove the fans.
    • Unscrew the four screws on the speakers (two screws on each)
    • Make sure to unplug the connector on each of the speakers and place them to the side
  6. Razer Blade 15 Keyboard Replacement, Remove the Motherboard and Hinges: 步骤 6 中的图像 1,1
    • Remove the two screws on each hinge and pick up the black pieces
    • Locate the seven screws holding down the motherboard and remove them
    • Remove the plastic headphone jack cover
    • Lift up the MOBO and place it to the side
    • Be careful when handling the motherboard and make sure you’re wearing the anti-static band.
  7. Razer Blade 15 Keyboard Replacement, Replacing the Keyboard: 步骤 7 中的图像 1,1
    • Unscrew the LCD
    • Slide the LCD connectors through the opening at the top when removing the LCD
    • Slide the LCD connectors of the new LCD through the opening at the top
    • Screw the new LCD back into the bottom case
    • Make sure all of the cables are in sight once the motherboard has been placed down
    • Screw in both the motherboard screws and the hinges
    • Reconnect the motherboard connectors
    • Place and screw in the fans and speakers
    • Make sure the SSD has been reconnected and screwed in
    • Screw the battery back in and reconnect the battery
结论
Make sure all of the keys on the keyboard are working properly. Once done, call the user to pick up their laptop.
另外一个人完成了本指南。
Ved Pitre
于10/30/19注册
1,092 声望
创作了5篇指南
3条评论
Thank you, I have one question, if you could help me…
Which one is the MOBO Cable for the keyboard backlight?
Daniel - 回复
Hello. I have Razer blade 2019 model. On Web cant Finder keybord gór this exact model. Keybord from 2020 model will fit or there are diffrence in build ?
Adrian Żaczek - 回复
Is this for the RZ09-03006E92-R3U1?
Ryan Zmuda - 回复
添加评论
浏览统计数据:
过去 24 小时: 3
过去 7 天: 6
过去 30 天: 21
总计 7,535
