跳转到主内容
Razer Blade 15 Advanced Model (Early 2020) Back Cover Replacement
你所需要的
  1. Razer Blade 15 Advanced Model (Early 2020) Back Cover Replacement, Unfasten the back cover: 步骤 1 中的图像 1,2 Razer Blade 15 Advanced Model (Early 2020) Back Cover Replacement, Unfasten the back cover: 步骤 1 中的图像 2,2
    • Use a T5 Torx driver to remove the ten 3.8 mm‑long screws securing the back cover.
  2. Razer Blade 15 Advanced Model (Early 2020) Back Cover Replacement, Insert an opening pick: 步骤 2 中的图像 1,3 Razer Blade 15 Advanced Model (Early 2020) Back Cover Replacement, Insert an opening pick: 步骤 2 中的图像 2,3 Razer Blade 15 Advanced Model (Early 2020) Back Cover Replacement, Insert an opening pick: 步骤 2 中的图像 3,3
    • Depending on the age and condition of your laptop, the back cover may come off sooner than this guide instructs. If it feels loose, remove it at any time.
    • Apply a suction handle to the middle of the back cover's right edge, between the lower rubber foot and the middle screws.
    • Pull up on the suction handle to create a small gap between the back cover and the frame.
    • Insert an opening pick into the gap.
  3. Razer Blade 15 Advanced Model (Early 2020) Back Cover Replacement, Angle the opening pick: 步骤 3 中的图像 1,3 Razer Blade 15 Advanced Model (Early 2020) Back Cover Replacement, Angle the opening pick: 步骤 3 中的图像 2,3 Razer Blade 15 Advanced Model (Early 2020) Back Cover Replacement, Angle the opening pick: 步骤 3 中的图像 3,3
    • Angle your opening pick upward, away from the frame. Keep it angled upward as long as it's between the back cover and the frame.
  4. Razer Blade 15 Advanced Model (Early 2020) Back Cover Replacement, Free the bottom right corner: 步骤 4 中的图像 1,3 Razer Blade 15 Advanced Model (Early 2020) Back Cover Replacement, Free the bottom right corner: 步骤 4 中的图像 2,3 Razer Blade 15 Advanced Model (Early 2020) Back Cover Replacement, Free the bottom right corner: 步骤 4 中的图像 3,3
    • Slide your opening pick around the bottom right corner of the back cover to free it from the frame.
  5. Razer Blade 15 Advanced Model (Early 2020) Back Cover Replacement, Free the front edge: 步骤 5 中的图像 1,3 Razer Blade 15 Advanced Model (Early 2020) Back Cover Replacement, Free the front edge: 步骤 5 中的图像 2,3 Razer Blade 15 Advanced Model (Early 2020) Back Cover Replacement, Free the front edge: 步骤 5 中的图像 3,3
    • Slide your opening pick along the front edge and around the front left corner of the back cover to free it from the frame completely.
  6. Razer Blade 15 Advanced Model (Early 2020) Back Cover Replacement, Remove the back cover: 步骤 6 中的图像 1,3 Razer Blade 15 Advanced Model (Early 2020) Back Cover Replacement, Remove the back cover: 步骤 6 中的图像 2,3 Razer Blade 15 Advanced Model (Early 2020) Back Cover Replacement, Remove the back cover: 步骤 6 中的图像 3,3
    • Remove the back cover.
    • Lay the back cover down on its rubber feet to avoid damaging the thermal pads.
结论
另外一个人完成了本指南。
Spencer Day
于09/14/22注册
155,036 声望
创作了1,033篇指南
团队
iFixit iFixit 的会员
Staff
123 名成员
创作了23,774篇指南
1指南评论
Buenas noches tu vendes la tapa trasera del Razer Blade 15 Advanced Model (Early 2020) RZ09-033
Germán Hernández - 回复
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 14
过去 30 天: 42
总计 1,249
