跳转到主内容
Razer Blade 14" (2013) Battery Replacement
你所需要的
  1. Razer Blade 14" (2013) Battery Replacement, Remove the back cover: 步骤 1 中的图像 1,2 Razer Blade 14" (2013) Battery Replacement, Remove the back cover: 步骤 1 中的图像 2,2
    • Remove all 10 Torx T5 Screws
  2. Razer Blade 14" (2013) Battery Replacement, Disconnect the keyboard cables: 步骤 2 中的图像 1,3 Razer Blade 14" (2013) Battery Replacement, Disconnect the keyboard cables: 步骤 2 中的图像 2,3 Razer Blade 14" (2013) Battery Replacement, Disconnect the keyboard cables: 步骤 2 中的图像 3,3
    • Flip the hold down up
    • Remove the cable
    • Repeat for second cable
  3. Razer Blade 14" (2013) Battery Replacement, Remove Touchpad cable: 步骤 3 中的图像 1,3 Razer Blade 14" (2013) Battery Replacement, Remove Touchpad cable: 步骤 3 中的图像 2,3 Razer Blade 14" (2013) Battery Replacement, Remove Touchpad cable: 步骤 3 中的图像 3,3
    • Unclip hold-down
    • Remove cable
  4. Razer Blade 14" (2013) Battery Replacement, Disconnect Battery: 步骤 4 中的图像 1,3 Razer Blade 14" (2013) Battery Replacement, Disconnect Battery: 步骤 4 中的图像 2,3 Razer Blade 14" (2013) Battery Replacement, Disconnect Battery: 步骤 4 中的图像 3,3
    • Use a spudger to disconnect the plug from the connector by pulling it away from the socket, parallel to the board.
    • Bend the connector backwards to prevent it from getting in the way of the motherboard.
  5. Razer Blade 14" (2013) Battery Replacement, Remove Battery Screws: 步骤 5 中的图像 1,2 Razer Blade 14" (2013) Battery Replacement, Remove Battery Screws: 步骤 5 中的图像 2,2
    • Remove the 7 battery screws
  6. Razer Blade 14" (2013) Battery Replacement, Remove the Battery: 步骤 6 中的图像 1,2 Razer Blade 14" (2013) Battery Replacement, Remove the Battery: 步骤 6 中的图像 2,2
    • Remove the battery by pulling up from the side closest to the motherboard
    • Be careful of the other cables and the battery cable
    • You will have to lift up just a bit, then slide forward to clear one cable and the back cover screws
结论
21等其他人完成本指南。
tallme15
于03/09/13注册
902 声望
创作了2篇指南
17条评论
i want buy a battery for razer blade but I can't buy it anywhere
Please help me, my battery only 20% heathly
dinhphucloctmx - 回复
It seems that the only way to get the battery replaced is to send the laptop to Razer directly. According to others it costs about $200 plus shipping and so on. Unless you find something on eBay or that sort of thing.
tallme15 -
May I have a detailed guide on how you remove the cable over the battery, please? I am not used to taking machines apart, and wouldn't want to risk ruining my laptop. (didn't quite understand your pictures)
ceci - 回复
The only way to remove the cable is to work it out with a set of tweezers and be gentle not to pull the cables lose from the connector.
Samer Sultan -
Thank you for these instructions, it was very helpful, the only problem is now that the new battery has been installed, it will only charge to 73% and while its still plugged in the battery will drain down to 0%, is there a fix for this problem?
Jay - 回复
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 8
过去 30 天: 24
总计 28,059
