跳转到主内容
Razer Blackwidow Tournament Edition Keyboard USB Port Board Replacement
你所需要的
  1. Razer Blackwidow Tournament Edition Keyboard USB Port Board Replacement, USB Port Board: 步骤 1 中的图像 1,3 Razer Blackwidow Tournament Edition Keyboard USB Port Board Replacement, USB Port Board: 步骤 1 中的图像 2,3 Razer Blackwidow Tournament Edition Keyboard USB Port Board Replacement, USB Port Board: 步骤 1 中的图像 3,3
    • Remove the four plastic covers and rubber feet from all four corners of the keyboard.
    • Remove the four screws.
    • Carefully pry around the bottom end of the keyboard and work your way around keyboard to un-clip the face.
  2. Razer Blackwidow Tournament Edition Keyboard USB Port Board Replacement: 步骤 2 中的图像 1,2 Razer Blackwidow Tournament Edition Keyboard USB Port Board Replacement: 步骤 2 中的图像 2,2
    • Turn the keyboard face up.
    • Remove the four screws which attach the keys.
    • Note the orientation of the white plastic cover relative to the LED at the bottom of the board.
  3. Razer Blackwidow Tournament Edition Keyboard USB Port Board Replacement: 步骤 3 中的图像 1,1
    • Locate the USB at the top of the device.
    • Remove the two screws attaching the USB.
  4. Razer Blackwidow Tournament Edition Keyboard USB Port Board Replacement: 步骤 4 中的图像 1,2 Razer Blackwidow Tournament Edition Keyboard USB Port Board Replacement: 步骤 4 中的图像 2,2
    • Unplug the cable connecting to the USB board.
    • Plug the new USB board into the slot.
    • Replace the screws in the USB board.
结论
另外一个人完成了本指南。
4条评论
hi, where do i get the new board from? thanks!
Doge The Best - 回复
You can easily find it on Ebay
Here's a link, i had the same issue
https://www.ebay.com/itm/272275162673htt...
iixroyal owlroyal -
Hey, you can easily Google the details on the USB board bottom left
I had the same issue
iixroyal owlroyal - 回复
添加评论
浏览统计数据:
过去 24 小时: 3
过去 7 天: 10
过去 30 天: 31
总计 5,038
