跳转到主内容
Razer Blackwidow Tournament Edition Keyboard Metal Bar on Keys Replacement
你所需要的
  1. Razer Blackwidow Tournament Edition Keyboard Metal Bar on Keys Replacement, Metal Bar on Keys: 步骤 1 中的图像 1,1
    • Before you do anything, take a picture of the entire keyboard so as to know where the keys go at the end.
    • Gently start to remove the keys surrounding the keys with the bars in them.
  2. Razer Blackwidow Tournament Edition Keyboard Metal Bar on Keys Replacement: 步骤 2 中的图像 1,3 Razer Blackwidow Tournament Edition Keyboard Metal Bar on Keys Replacement: 步骤 2 中的图像 2,3 Razer Blackwidow Tournament Edition Keyboard Metal Bar on Keys Replacement: 步骤 2 中的图像 3,3
    • Move the key itself off of one side of the bar from where it connects to easily allow the other side to be removed as well.
    • Another way to do it is to push the bar itself out gently with the metal spudger.
  3. Razer Blackwidow Tournament Edition Keyboard Metal Bar on Keys Replacement: 步骤 3 中的图像 1,2 Razer Blackwidow Tournament Edition Keyboard Metal Bar on Keys Replacement: 步骤 3 中的图像 2,2
    • Gently pop the bar out from its sockets.
    • Pop the new bar back into the sockets.
  4. Razer Blackwidow Tournament Edition Keyboard Metal Bar on Keys Replacement: 步骤 4 中的图像 1,1
    • Gently slide one side of the key into the bar and then use the metal spudger to pop the other side into place.
    • Use the picture from the beginning if necessary to make sure all the keys are in the right place.
结论
一条评论
I bought my keyboard second hand have I either gotten a different keyboard or have the lad's been removed or is it a different model as I still have the Fn key which usually turns them on.
BettyBulldog123 a.k.a Betty - 回复
添加评论
浏览统计数据:
过去 24 小时: 4
过去 7 天: 11
过去 30 天: 38
总计 4,260
