跳转到主内容
Razer Blackwidow Tournament Edition Chroma Back Panel Replacement
你所需要的
  1. Razer Blackwidow Tournament Edition Chroma Back Panel Replacement, Rubber Feet: 步骤 1 中的图像 1,2 Razer Blackwidow Tournament Edition Chroma Back Panel Replacement, Rubber Feet: 步骤 1 中的图像 2,2
    • Turn the keyboard over so that it is lying flat on its face.
    • Use the iFixit opening tool to pry the rubber feet off the keyboard.
  2. Razer Blackwidow Tournament Edition Chroma Back Panel Replacement, Front Panel: 步骤 2 中的图像 1,2 Razer Blackwidow Tournament Edition Chroma Back Panel Replacement, Front Panel: 步骤 2 中的图像 2,2
    • Use a Phillips #1 screwdriver to remove the six screws on the back of the keyboard.
    • Use an opening tool as a wedge between the front and back panel to pry open the front panel.
    • If the front and back panel won't separate, DO NOT use excessive force. This may result in damaging the keyboard.
    • Instead, slide the opening tool across the keyboard in between the front and back panel. Go around the edges of the keyboard until the panels disconnect.
    • Flip the keyboard over so the keys are facing up.
    • Grabbing the left and right lips of the front panel, lift both ends up, removing the front panel.
  3. Razer Blackwidow Tournament Edition Chroma Back Panel Replacement, Back Panel: 步骤 3 中的图像 1,2 Razer Blackwidow Tournament Edition Chroma Back Panel Replacement, Back Panel: 步骤 3 中的图像 2,2
    • Use a Philips #1 Screwdriver to remove the four screws located below the keys.
    • Lift the main circuit board and flip it over, placing it on its top.
    • Be cautious of the wire connected to the USB Port Board.
结论
另外一个人完成了本指南。
0条评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 13
过去 30 天: 30
总计 2,386
