跳转到主内容
Razer BlackWidow V4 Keycap Replacement
你所需要的
  1. Razer BlackWidow V4 Keycap Replacement, Keycap: 步骤 1 中的图像 1,1
    • With key cap tweezers, align and grasp the edges of the keycap with force.
    • Once you have a firm grasp, push in and up.
  2. Razer BlackWidow V4 Keycap Replacement: 步骤 2 中的图像 1,1
    • After the keycap is off the keyboard from the center holder, simply pull up and place to the side.
    • Make sure to remember the orientation in which the keyboard was facing.
  3. Razer BlackWidow V4 Keycap Replacement: 步骤 3 中的图像 1,1
    • Use a spudger to realign the clip on the keyboard by simply pushing down on the side or center of the clip.
    • Make sure the clip is tucked in the center and both ends of the clip are parallel to each other making sure there is a keyboard wall inside the clip.
  4. Razer BlackWidow V4 Keycap Replacement: 步骤 4 中的图像 1,1
    • Use either a dust cleaner or Co2 compressor to spray away any debris that may be inside the holder.
    • Make sure the clip does not fly away.
  5. Razer BlackWidow V4 Keycap Replacement: 步骤 5 中的图像 1,1
    • With a caliper, measure the diameter of the fitment on the keyboard.
    • The measurements can either be of the side wall or center clip.
    • You can also use a ruler for this step.
  6. Razer BlackWidow V4 Keycap Replacement: 步骤 6 中的图像 1,1
    • Measure the diameter of fitment on the keycap.
    • They should be the same or off by .02+/- .
    • If the fitment is bigger or smaller than .02+/- do not try and force it in. This will cause keyboard issues.
  7. Razer BlackWidow V4 Keycap Replacement: 步骤 7 中的图像 1,1
    • Add a drop of keyboard cap lubricant to make sure that any friction or shear pressure is dispersed evenly throughout the lifespan of the keycap.
  8. Razer BlackWidow V4 Keycap Replacement: 步骤 8 中的图像 1,1
    • Identify the orientation of which the keycap has to enter by noticing the clip holder on the keycap and the keyboard.
    • If the keyboard cap is OEM from Razer you do not need to worry about this step. The keycap contains a safety spacer that will not allow you to place it out of orientation.
  9. Razer BlackWidow V4 Keycap Replacement: 步骤 9 中的图像 1,1
    • With a slight force press down and hold.
    • Once the keyboard has been clicked in successfully, enjoy your keyboard.
终点
另外一个人完成了本指南。
Hemi_perez2000
于02/21/24注册
173 声望
撰写一个指南
团队
CSU Sacramento, Team 1-4, Laflen Spring 2024 CSU Sacramento, Team 1-4, Laflen Spring 2024 的会员
CSUSAC-LAFLEN-S24S1G4
1 名成员
创作了1篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 3
过去 30 天: 42
总计 85
