跳转到主内容
Razer BlackWidow Chroma Lights Replacement
你所需要的
  1. Razer BlackWidow Chroma Lights Replacement, Lights: 步骤 1 中的图像 1,1
    • Gently pull off the four rubber tabs located on the corners of the keyboard with your fingers.
  2. Razer BlackWidow Chroma Lights Replacement: 步骤 2 中的图像 1,1
    • Using a metal spudger, gently remove the plastic tabs that are covering the two screws.
  3. Razer BlackWidow Chroma Lights Replacement: 步骤 3 中的图像 1,1
    • There are six 10mm screws indicated by the red markups . Remove the screws using the Phillips #0 Screwdriver.
  4. Razer BlackWidow Chroma Lights Replacement: 步骤 4 中的图像 1,2 Razer BlackWidow Chroma Lights Replacement: 步骤 4 中的图像 2,2
    • Using a metal spudger, begin prying off the faceplate of the keyboard. There are small tabs along the edge of the keyboard and the faceplate that must be released. There are four tabs along the front of the keyboard and two along each side.
  5. Razer BlackWidow Chroma Lights Replacement: 步骤 5 中的图像 1,1
    • Using a plastic opening tool, lift the plastic covering away from the LED light.
  6. Razer BlackWidow Chroma Lights Replacement: 步骤 6 中的图像 1,2 Razer BlackWidow Chroma Lights Replacement: 步骤 6 中的图像 2,2
    • Using the Phillips #0 Screwdriver, remove the ten 10mm screws that are indicated by the red markers.
    • Click the link below to watch a video that will guide you through the rest of the steps on how to replace LEDs in the keyboard. This step does require soldering . How to Replace Back-light LEDs
结论
3等其他人完成本指南。
团队
UW Tacoma, Team 2-6, Rose Winter 2017 UW Tacoma, Team 2-6, Rose Winter 2017 的会员
UWT-ROSE-W17S2G6
3 名成员
创作了4篇指南
2条评论
Anyone know what type of LEDs are need for the replacement?
Huayu Nie - 回复
High brightness led’s, 3mm.
Carlos Eduardo Pereira Reis -
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 16
过去 30 天: 65
总计 18,254
