跳转到主内容
Razer BlackWidow Chroma Key Replacement
你所需要的
  1. Razer BlackWidow Chroma Key Replacement, Key: 步骤 1 中的图像 1,1
    • If the problematic key is still attached, place the edge of the medium blue pry tool under the key. Then gently pry up until key is detached.
  2. Razer BlackWidow Chroma Key Replacement: 步骤 2 中的图像 1,1
    • Some larger keys may also be held in by two small metal hooks. To separate them gently slide the key left to separate right hook, then to the right to separate the left hook. Be careful not to break the mounting holes on the key itself.
结论
7等其他人完成本指南。
Kirk Foreman
于02/01/17注册
248 声望
撰写一个指南
团队
UW Tacoma, Team 2-6, Rose Winter 2017 UW Tacoma, Team 2-6, Rose Winter 2017 的会员
UWT-ROSE-W17S2G6
3 名成员
创作了3篇指南
3条评论
This has absolutely nothing to do with fixing a stuck key. Useless information.
Kyle - 回复
99% of steps to replace a key is missing. What a joke.
Jacinto - 回复
please change the name to “keycap” I don’t see this as useless but, misleading.
Shaun Conklin - 回复
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 19
过去 30 天: 61
总计 12,759
