简介
If your Razer Basilisk V3 is malfunctioning or requires internal maintenance, this guide will help you safely remove the backplate to access its internal components. This is necessary for performing tasks such as replacing faulty parts or cleaning. The steps involve unscrewing, carefully separating the mouse's halves, and handling them thoughtfully to avoid damaging the connectors.
你所需要的
Remove two 4.8 mm screws that were hidden under the front skates using a JIS #1 screwdriver.
Remove the single 4 mm screw beneath the thumb grip using a JIS #1 screwdriver.
结论
