跳转到主内容
Raspberry Pi 3 SD Card Replacement
你所需要的
  1. Raspberry Pi 3 SD Card Replacement, Raspberry Pi 3 SD Card replacement.: 步骤 1 中的图像 1,1
    • The Raspberry Pi 3 should look like this closed.
  2. Raspberry Pi 3 SD Card Replacement, Top cover removal: 步骤 2 中的图像 1,1
    • Open the top lid like I have done on the image.
    • The top is marked that you are gonna remove in the next step.
  3. Raspberry Pi 3 SD Card Replacement, Cover for GPIO Hider and IO Shield removal: 步骤 3 中的图像 1,1
    • Now remove the cover for the two covers.
    • It should look like the image.
    • I have marked the covers for the next step.
  4. Raspberry Pi 3 SD Card Replacement, IO Shield and GPIO Hider removal: 步骤 4 中的图像 1,1
    • Remove the two sides.
  5. Raspberry Pi 3 SD Card Replacement, Removal.: 步骤 5 中的图像 1,2 Raspberry Pi 3 SD Card Replacement, Removal.: 步骤 5 中的图像 2,2
    • Now we should successfully have removed the case.
    • Notice that the side shown on the first image is the one that we are intrested in.
    • When we have flipped the Pi 3 over we can remove the SD card.
结论
5等其他人完成本指南。
ΛΛKΛRΞT
于11/22/17注册
229 声望
撰写一个指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 8
过去 30 天: 26
总计 2,386
