跳转到主内容
Raptor 2 / T REX 3 Y End Stop Adaptor
你所需要的
  1. Raptor 2 / T REX 3 Y End Stop Adaptor, Y End Stop Adaptor: 步骤 1 中的图像 1,3 Raptor 2 / T REX 3 Y End Stop Adaptor, Y End Stop Adaptor: 步骤 1 中的图像 2,3 Raptor 2 / T REX 3 Y End Stop Adaptor, Y End Stop Adaptor: 步骤 1 中的图像 3,3
    • Retain all fasteners until after assembly.
    • Find the file for printing at http://bit.ly/2RFHGyT
    • To start this process, you will need to remove all 4 corner leveling knobs. There may also be a star washer between the knob and Y carriage plate on each corner.
    • The screw that is not allowing the new chain to sit flat, needs to be removed. Use an M2.5 hex for this.
    • The screw is no longer needed.
    • The raised part sits closer to one side. It should face the end stop.
    • Test fit the printed part first to make sure it sits all the way flush.
  2. Raptor 2 / T REX 3 Y End Stop Adaptor, Y End Stop Adaptor: 步骤 2 中的图像 1,3 Raptor 2 / T REX 3 Y End Stop Adaptor, Y End Stop Adaptor: 步骤 2 中的图像 2,3 Raptor 2 / T REX 3 Y End Stop Adaptor, Y End Stop Adaptor: 步骤 2 中的图像 3,3
    • Loosen the socket head screw using a M4 hex .
    • Reposition the end stop so that the new printed part triggers the lever.
    • Using a RTV silicone based adhesive (high temp suggested) or another glue that works with plastic/metal, apply a small amount of glue to the sides of the printed part on the inside corner.
  3. Raptor 2 / T REX 3 Y End Stop Adaptor, Y End Stop Adaptor: 步骤 3 中的图像 1,2 Raptor 2 / T REX 3 Y End Stop Adaptor, Y End Stop Adaptor: 步骤 3 中的图像 2,2
    • Clean up any excess glue using a paper towel.
    • Double check that the end stop is triggered by the new part. Reposition the end stop bracket if necessary.
    • Tighten the end stop bracket.
    • This is held in with a bolt and T Nut. Make sure the bracket is secure after tightening the bolt.
    • Continue on with Step 10 on the Cable Chain Install Guide by clicking http://bit.ly/2Runj7r.
结论
Tiny Machines 3D
于11/16/19注册
2,970 声望
创作了14篇指南
团队
Tiny Machines 3D Tiny Machines 3D 的会员
Community
5 名成员
创作了40篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 2
过去 30 天: 14
总计 146
