跳转到主内容
Raleigh M20 Seat Cushion Replacement
你所需要的
  1. Raleigh M20 Seat Cushion Replacement, Seat Cushion: 步骤 1 中的图像 1,3 Raleigh M20 Seat Cushion Replacement, Seat Cushion: 步骤 1 中的图像 2,3 Raleigh M20 Seat Cushion Replacement, Seat Cushion: 步骤 1 中的图像 3,3
    • Loosen the seat clamp by pulling the black lever away from the frame. Once this is done, simply rotate the lever counter-clockwise to loosen the seat.
    • Stand on the right side of the bike while loosening the lever and make sure the bike isn't upside-down. This will prevent the seat from falling off during this process.
  2. Raleigh M20 Seat Cushion Replacement: 步骤 2 中的图像 1,2 Raleigh M20 Seat Cushion Replacement: 步骤 2 中的图像 2,2
    • Now that the seat is loosened, slowly pull up on the seat cushion until it is fully out of the frame. Next, place the seat on the ground.
  3. Raleigh M20 Seat Cushion Replacement: 步骤 3 中的图像 1,2 Raleigh M20 Seat Cushion Replacement: 步骤 3 中的图像 2,2
    • Use an Allen wrench to unscrew the bolt that is holding the post to the seat cushion.
  4. Raleigh M20 Seat Cushion Replacement: 步骤 4 中的图像 1,3 Raleigh M20 Seat Cushion Replacement: 步骤 4 中的图像 2,3 Raleigh M20 Seat Cushion Replacement: 步骤 4 中的图像 3,3
    • Now that the bolt is loosened, carefully pull the seat cushion from the post. Next remove the two riders as shown in the second image.
结论
Now you are ready to reassemble the seat with your new cushion. Just follow these same steps in the reverse order. Thanks for taking the time to use this guide!
另外一个人完成了本指南。
团队
Cal Poly, Team 7-49, Forte Fall 2012 Cal Poly, Team 7-49, Forte Fall 2012 的会员
CPSU-FORTE-F12S7G49
5 名成员
创作了5篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 12
总计 1,963
