跳转到主内容
加入维修社区 - 创建账户
Raleigh M20 Handlebars Replacement
你所需要的
  1. Raleigh M20 Handlebars Replacement, Handlebars: 步骤 1 中的图像 1,2 Raleigh M20 Handlebars Replacement, Handlebars: 步骤 1 中的图像 2,2
    • Strip all the accessories from your old handlebars. (reflectors, mirrors, etc...)
    • Using a 3/8" Allen wrench, loosen the nuts that hold the brake controls and gear shifters.
  2. Raleigh M20 Handlebars Replacement: 步骤 2 中的图像 1,3 Raleigh M20 Handlebars Replacement: 步骤 2 中的图像 2,3 Raleigh M20 Handlebars Replacement: 步骤 2 中的图像 3,3
    • Place an Allen wrench (size doesn't matter) under the bike grip.
    • Twist the grip back and forth while pulling on the Allen wrench to remove the grip.
  3. Raleigh M20 Handlebars Replacement: 步骤 3 中的图像 1,2 Raleigh M20 Handlebars Replacement: 步骤 3 中的图像 2,2
    • Slide off the gear shifters.
    • Slide off the brake controls.
  4. Raleigh M20 Handlebars Replacement: 步骤 4 中的图像 1,3 Raleigh M20 Handlebars Replacement: 步骤 4 中的图像 2,3 Raleigh M20 Handlebars Replacement: 步骤 4 中的图像 3,3
    • Loosen the central nut on the faceplate that connects the bars to the steering column. If the bars are secured by a faceplate with a detachable top, loosen the nuts on the faceplate and remove.
    • Lift the handlebars from the bike frame.
    • Move the bars until they're in the correct position for your stance. Tighten the faceplate nuts with a 3/8" Allen wrench to firmly secure the handlebars in place.
    • Sit on the bike and make final adjustments to the positioning of the brakes and gears.
结论
To reinstall the handlebars, complete these steps in reverse order. If there is a problem with the alignment, return to the handlebar repair guide and repeat step 4.
Jon Ribera
于09/26/12注册
72 声望
撰写一个指南
团队
Cal Poly, Team 7-49, Forte Fall 2012 Cal Poly, Team 7-49, Forte Fall 2012 的会员
CPSU-FORTE-F12S7G49
5 名成员
创作了5篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 10
过去 30 天: 48
总计 2,431
