跳转到主内容
加入维修社区 - 创建账户
Raleigh M20 Chain Guard Replacement
你所需要的
  1. Raleigh M20 Chain Guard Replacement, Raleigh M20 Pedal Removal: 步骤 1 中的图像 1,1
    • Use an 8" adjustable crescent wrench to fit it into the base of the pedal.
  2. Raleigh M20 Chain Guard Replacement: 步骤 2 中的图像 1,2 Raleigh M20 Chain Guard Replacement: 步骤 2 中的图像 2,2
    • Twist the the wrench in a counter -clockwise direction to unscrew the right-side pedal (The chain side).
    • Repeat the process on the other side with a clockwise direction.
  3. Raleigh M20 Chain Guard Replacement: 步骤 3 中的图像 1,1
    • Turn the wrench continuously until the pedal detaches from the crank arm.
  4. Raleigh M20 Chain Guard Replacement, Chain Guard: 步骤 4 中的图像 1,2 Raleigh M20 Chain Guard Replacement, Chain Guard: 步骤 4 中的图像 2,2
    • Use a flathead screwdriver to remove the dust cap of the crank arm.
    • Repeat the process on other side.
  5. Raleigh M20 Chain Guard Replacement: 步骤 5 中的图像 1,2 Raleigh M20 Chain Guard Replacement: 步骤 5 中的图像 2,2
    • Next, use a socket wrench to unscrew the crank arm.
    • Turn the socket wrench clockwise to remove the bolt.
  6. Raleigh M20 Chain Guard Replacement: 步骤 6 中的图像 1,3 Raleigh M20 Chain Guard Replacement: 步骤 6 中的图像 2,3 Raleigh M20 Chain Guard Replacement: 步骤 6 中的图像 3,3
    • Insert the crank arm puller into the screw hole.
    • Now use a crescent wrench to tighten the crank arm puller. Twist it in a clockwise direction until the puller is fully tightened.
    • Do not over-tighten the crank arm puller. Stop once it's fully tightened.
  7. Raleigh M20 Chain Guard Replacement: 步骤 7 中的图像 1,3 Raleigh M20 Chain Guard Replacement: 步骤 7 中的图像 2,3 Raleigh M20 Chain Guard Replacement: 步骤 7 中的图像 3,3
    • Turn the crank arm puller in a clockwise direction to remove it.
    • There will be some resistance when removing the crank arm.
    • Repeat step 2 to 4 on the other side.
  8. Raleigh M20 Chain Guard Replacement: 步骤 8 中的图像 1,2 Raleigh M20 Chain Guard Replacement: 步骤 8 中的图像 2,2
    • Flip the crank arm over with the chainring on it.
    • Locate the four screws on the back of the chainring.
  9. Raleigh M20 Chain Guard Replacement: 步骤 9 中的图像 1,3 Raleigh M20 Chain Guard Replacement: 步骤 9 中的图像 2,3 Raleigh M20 Chain Guard Replacement: 步骤 9 中的图像 3,3
    • Use a Phillips #2 screwdriver to remove the four screws on the back of the chainring.
  10. Raleigh M20 Chain Guard Replacement: 步骤 10 中的图像 1,1
    • Flip the chain guard over.
  11. Raleigh M20 Chain Guard Replacement: 步骤 11 中的图像 1,2 Raleigh M20 Chain Guard Replacement: 步骤 11 中的图像 2,2
    • Hold on to the crank arm and pull out the chain guard gently.
结论
If you are replacing the chain guard, use the new chain guard when reassembling the device.
另外一个人完成了本指南。
Carl Lind
于09/26/12注册
55 声望
撰写一个指南
团队
Cal Poly, Team 7-49, Forte Fall 2012 Cal Poly, Team 7-49, Forte Fall 2012 的会员
CPSU-FORTE-F12S7G49
5 名成员
创作了5篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 4
过去 30 天: 20
总计 4,200
