跳转到主内容
Raleigh M20 Bicycle Rear Rack Replacement
你所需要的
  1. Raleigh M20 Bicycle Rear Rack Replacement, Bicycle Rear Rack: 步骤 1 中的图像 1,2 Raleigh M20 Bicycle Rear Rack Replacement, Bicycle Rear Rack: 步骤 1 中的图像 2,2
    • Make sure that the bike is upright and stable.
    • With both hands, place the rear rack on the rear wheel of the bike. Take note of where the rear rack will attach on the bike.
    • Make sure that the rear rack is fitted on the bike.
  2. Raleigh M20 Bicycle Rear Rack Replacement: 步骤 2 中的图像 1,3 Raleigh M20 Bicycle Rear Rack Replacement: 步骤 2 中的图像 2,3 Raleigh M20 Bicycle Rear Rack Replacement: 步骤 2 中的图像 3,3
    • Place a screw to attach the rear rack to the frame of the tire.
    • Tighten the screw with a philips screwdriver by turning it in a clockwise direction.
    • Repeat the steps above on the other side of the bike.
  3. Raleigh M20 Bicycle Rear Rack Replacement: 步骤 3 中的图像 1,3 Raleigh M20 Bicycle Rear Rack Replacement: 步骤 3 中的图像 2,3 Raleigh M20 Bicycle Rear Rack Replacement: 步骤 3 中的图像 3,3
    • Place the metal holder to be even with the bar sticking out of the rear rack.
    • Line up the holes. Place a bolt to attach them together.
    • Use a philips screwdriver to tighten the bolts.
    • Do this for both sides.
  4. Raleigh M20 Bicycle Rear Rack Replacement: 步骤 4 中的图像 1,2 Raleigh M20 Bicycle Rear Rack Replacement: 步骤 4 中的图像 2,2
    • Make sure that the rear rack is even. If it is not, redo the previous step.
    • Locate the screws on top of the rear rack. Tighten the screws using a philips screwdriver.
    • Once the screws are tightened, you are done.
结论
To detach the rear rack, follow the instructions of this guide in the reverse order.
另外一个人完成了本指南。
团队
Cal Poly, Team 7-49, Forte Fall 2012 Cal Poly, Team 7-49, Forte Fall 2012 的会员
CPSU-FORTE-F12S7G49
5 名成员
创作了5篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 8
总计 2,984
