简介
When a radiator is not getting warm, despite the valve being fully opened, it does not mean you have to call a heating technician right away.
Most likely it is only the transmission pin which controls the flow of hot water that is stuck and not moving as intended.
你所需要的
Add some additional lubrication to the pin before screwing the thermostat back on.
By pushing the pin in and let it come back out several times using the hammer again, the oil should evenly distribute on the pin, so that in future it is very unlikely, that it is seizing up soon again.
That's it! Put the valve/thermostat back on and fix it in place.
To reassemble your device, follow the steps in reverse order.
6等其他人完成本指南。
由衷感谢以下译者:
100%
这些译者帮助我们修补全世界! 您也想加入吗?
开始翻译 ›
