简介
If your grinder begins to malfunction because of gear issues, it's time to replace the grinding head assembly. The link below contains the information necessary to order a replacement from RYOBI's home webpage.
你所需要的
To remove the battery press down on the two buttons located on each side of the battery and pull away from the body of the grinder.
To remove the handle hold grinder with one hand and use the other hand to unscrew the handle with a counter-clockwise motion
Fully press the spindle lock button.
With the spindle lock button held down, use the wrench provided to loosen the clamp nut. Once loose, you can use your fingers to unscrew the nut completely
Remove the four 1.4 cm screws from the grinding head assembly using a Torx T20 screwdriver.
With the screws removed, the grinding head assembly can be removed from the rest of the head with a gentle pull.
