跳转到主内容
RYOBI P422 Body Replacement
你所需要的
  1. RYOBI P422 Body Replacement, Battery and Handle: 步骤 1 中的图像 1,2 RYOBI P422 Body Replacement, Battery and Handle: 步骤 1 中的图像 2,2
    • To remove the battery press down on the two buttons located on each side of the battery and pull away from the body of the grinder.
    • To remove the handle hold grinder with one hand and use the other hand to unscrew the handle with a counter-clockwise motion
  2. RYOBI P422 Body Replacement, Body: 步骤 2 中的图像 1,1
    • Lay the grinder flat on its side so the screws are facing up.
  3. RYOBI P422 Body Replacement: 步骤 3 中的图像 1,3 RYOBI P422 Body Replacement: 步骤 3 中的图像 2,3 RYOBI P422 Body Replacement: 步骤 3 中的图像 3,3
    • Remove the four 1.8 cm screws from the lower and mid section of the body with the Torx T20 screwdriver.
    • Remove the 3.7 cm screws from the upper section of the body, with the same screwdriver.
  4. RYOBI P422 Body Replacement: 步骤 4 中的图像 1,2 RYOBI P422 Body Replacement: 步骤 4 中的图像 2,2
    • Now that the two halves are unscrewed, lift up the top half.
  5. RYOBI P422 Body Replacement: 步骤 5 中的图像 1,3 RYOBI P422 Body Replacement: 步骤 5 中的图像 2,3 RYOBI P422 Body Replacement: 步骤 5 中的图像 3,3
    • Remove the safety trigger and the spring.
    • Be careful in removing the safety trigger, the pin may fall out as you are moving it.
  6. RYOBI P422 Body Replacement: 步骤 6 中的图像 1,2 RYOBI P422 Body Replacement: 步骤 6 中的图像 2,2
    • Lift up main trigger and spring together.
    • By lifting this trigger and spring out of the handle, you will pull double duty by lifting the black switch box off of its two support posts.
    • Slide the trigger off of the black switch box.
    • Be careful when removing trigger, the spring will be compressed and may move unexpectedly.
  7. RYOBI P422 Body Replacement: 步骤 7 中的图像 1,3 RYOBI P422 Body Replacement: 步骤 7 中的图像 2,3 RYOBI P422 Body Replacement: 步骤 7 中的图像 3,3
    在这个步骤中使用的工具:
    购买
    • Lift the battery lead bracket from its slot.
    • Use the PH 1 screwdriver to unscrew the two 0.7 cm screws that hold the 2.6 cm long brass bracket in place.
    • Use tweezers to remove the brass bracket.
    • During reassembly, remember to keep the spring inside the main trigger and against the bracket that is visible in the second of the accompanying photos.
  8. RYOBI P422 Body Replacement: 步骤 8 中的图像 1,2 RYOBI P422 Body Replacement: 步骤 8 中的图像 2,2
    • Flip the grinder over and lift off the second half of the body.
    • Now you can replace your damaged handles with a new pair.
结论
2等其他人完成本指南。
John Lamanuzzi
于03/20/15注册
229 声望
创作了2篇指南
团队
UMass Dartmouth, Team 3-6, Duarte Spring 2015 UMass Dartmouth, Team 3-6, Duarte Spring 2015 的会员
UMASSD-DUARTE-S15S3G6
3 名成员
创作了5篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 2
过去 30 天: 9
总计 1,386
