简介
If your RYOBI AG454 is not working or turning on, your motor could be damaged. If the device is sputtering or smoke this could be a sign of motor damage. This guide explains how to detect issues in the motor. It will go through the process of how to understand that the issue is coming from the motor. It will then go through the process of taking apart the grinder so they can reach the motor. After this process, it will give the user helpful steps on how to see if the issue is fixable or not.
你所需要的
Remove the brush caps from each side of the body using the 4 mm flat head screwdriver.
