简介
If your angle grinder suddenly stops working a common problem is that your brushes are worn out. Carbon brushes wear overtime so they will need to be replaced every so often. This replacement guide explains how the brushes can malfunction and how you can fix certain issues.
你所需要的
Remove the brush caps from each side of the body using the 4 mm flat head screwdriver.
即将完成!
结论
另外一个人完成了本指南。
