跳转到主内容
ROYALAXE R68 TKL Key Switches Replacement
你所需要的
  1. ROYALAXE R68 TKL Key Switches Replacement, Key Switches: 步骤 1 中的图像 1,2 ROYALAXE R68 TKL Key Switches Replacement, Key Switches: 步骤 1 中的图像 2,2
    • Unplug the keyboard from its power source.
  2. ROYALAXE R68 TKL Key Switches Replacement: 步骤 2 中的图像 1,1
    • Remove all keycaps with the keycap puller.
    • You can line up the keycaps in order or take a picture of your keyboard to make it easier to put them back on at the end.
  3. ROYALAXE R68 TKL Key Switches Replacement: 步骤 3 中的图像 1,2 ROYALAXE R68 TKL Key Switches Replacement: 步骤 3 中的图像 2,2
    • Clean the keyboard using a compressed air duster and a small brush or cotton swab.
    • You can also clean your keycaps by soaking them in a bowl with water and soap for about 30 minutes.
  4. ROYALAXE R68 TKL Key Switches Replacement: 步骤 4 中的图像 1,2 ROYALAXE R68 TKL Key Switches Replacement: 步骤 4 中的图像 2,2
    • Remove the switches with the switch puller.
    • Make sure to clamp on the switch vertically instead of horizontally. Then gently pull it out.
    • Taking out the switch by pulling horizontally could damage the switch.
  5. ROYALAXE R68 TKL Key Switches Replacement: 步骤 5 中的图像 1,3 ROYALAXE R68 TKL Key Switches Replacement: 步骤 5 中的图像 2,3 ROYALAXE R68 TKL Key Switches Replacement: 步骤 5 中的图像 3,3
    • Make sure the copper part of the switch faces you when you try to insert the switch.
    • Insert the key switch as straight as possible and press down gently until you hear a click.
    • If you fail to line it up, it will bend the copper part under the switch. This will permanently damage the switch.
  6. ROYALAXE R68 TKL Key Switches Replacement: 步骤 6 中的图像 1,2 ROYALAXE R68 TKL Key Switches Replacement: 步骤 6 中的图像 2,2
    • Place keycaps in their respective position.
    • Make sure all keys are operating well.
    • Enjoy your new switches!
终点
另外一个人完成了本指南。
Angie
于10/25/23注册
163 声望
撰写一个指南
团队
CSU Los Angeles, Team 4-5, Kershman Fall 2023 CSU Los Angeles, Team 4-5, Kershman Fall 2023 的会员
CSULA-KERSHMAN-F23S4G5
1 名成员
创作了1篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 10
总计 165
