跳转到主内容
ROG Zephyrus G14 SSD and RAM Replacement
你所需要的
  1. ROG Zephyrus G14 SSD and RAM Replacement, Opening The Laptop: 步骤 1 中的图像 1,2 ROG Zephyrus G14 SSD and RAM Replacement, Opening The Laptop: 步骤 1 中的图像 2,2
    • Flip over the laptop and locate all 14 of the screws. Follow the last image to find and remove all screws, noting the different sizes. *M2.5x6 doesn't get removed, marked in red.
    • 10 M2x9.5 Screws
    • 3 M2x4.5 Screws
    • 1 M2.5x6 Pop-Open Screw (do not remove)
    • Make sure device is completely powered off!
  2. ROG Zephyrus G14 SSD and RAM Replacement, Disconnect Battery: 步骤 2 中的图像 1,2 ROG Zephyrus G14 SSD and RAM Replacement, Disconnect Battery: 步骤 2 中的图像 2,2
    • Locate the battery connector, and unplug the battery to make sure you're safe before we continue. For this, slide the little chrome part back and lift the White plastic piece straight up
    • An anti-static wrist strap may be helpful to lower the risk of static discharge. (optional)
  3. ROG Zephyrus G14 SSD and RAM Replacement, RAM Replacement: 步骤 3 中的图像 1,1
    • To upgrade the RAM, peel the black cover on the right side to reveal the socket underneath.
    • Move the metal retention clip(s) by pushing down and outward
    • Insert the new module: look for the keying on the module and PCB. It can only be inserted one way.
    • Push down on the RAM like a hinge until the retention clip(s) grab onto the module.
  4. ROG Zephyrus G14 SSD and RAM Replacement, SSD Replacement: 步骤 4 中的图像 1,2 ROG Zephyrus G14 SSD and RAM Replacement, SSD Replacement: 步骤 4 中的图像 2,2
    • To replace the storage, locate the M.2 SSD under the longer black strip on the left.
    • Remove the screw holding it down. Proceed to pull the SSD out towards the outside of the chassis.
    • Slide the new SSD in making note of the keying as it may only be inserted one way (similar to RAM). You should be inserting it at a roughly 30-45 degree angle.
    • The G14 uses an M key slot. B-Key drives are unsupported. SATA drives (B + M) may work, but aren't recommended
    • Re-insert the screw to hold to new SSD in place.
  5. ROG Zephyrus G14 SSD and RAM Replacement, Battery: 步骤 5 中的图像 1,1
    • Put the plastic connector of the battery back on and slide the chrome piece back over it.
  6. ROG Zephyrus G14 SSD and RAM Replacement, Reassembly: 步骤 6 中的图像 1,1
    • Put the back cover on and put all the screws back
    • Around the top edge are a few plastic clips that should snap into place.
    • Make sure to put the screws back in the correct location to avoid accidental damage.
结论
When booting back up make sure to not freak out if it doesn’t start right away it does take a minute for the first boot up due to the laptop trying to register the new parts.
5等其他人完成本指南。
团队
CSU Los Angeles, Team 3-93, Briggs Fall 2023 CSU Los Angeles, Team 3-93, Briggs Fall 2023 的会员
CSULA-BRIGGS-F23S3G93
1 名成员
创作了4篇指南
3指南评论
Are both or just one RAM stick changeable?
C Sides - 回复
Just one is changeable. Sadly, the other is soldered to the board, so any upgrades will be in Single-Channel.
Phase -
I have this laptop and I hate/love it. It's a great laptop and plays games very well... until it randomly restarts mid gameplay, typically during "busy" moments. If one were to suspect the soldered on RAM being the culprit for this behavior, where are said RAM chips on the mobo? I presume they're BGA chips, but I ain't scurred to attempt replacing them.
Strual - 回复
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 69
过去 30 天: 315
总计 8,595
