简介
The Asus ROG Strix G15 G512LI Has 2 SO-DIMM Slots And is capable of running up to 2933MHz DDR4.
It has a capacity of 32GBs of ram.
Remove the screws from the compartment cover, As show in the diagram, unscrew the screws labeled "A" first. before unscrewing "B", Don't remove screw "B" from the cover.
Locate the RAM Slots.
If you are replacing your RAM, take the RAM out and insert a new stick at a 30 degree angle, and push down the RAM module until it clicks into place.
If you are adding another module into the system, make sure it is compatible with the laptop before installation
2等其他人完成本指南。
