跳转到主内容
RK5 PLUS VR Headset Headband Replacement
你所需要的
  1. RK5 PLUS VR Headset Headband Replacement, Headband: 步骤 1 中的图像 1,3 RK5 PLUS VR Headset Headband Replacement, Headband: 步骤 1 中的图像 2,3 RK5 PLUS VR Headset Headband Replacement, Headband: 步骤 1 中的图像 3,3
    • Place the headset right side up and facing you on a flat surface.
    • Gently detach the velcro straps from the top, left, and right sides of the headset and set them aside.
  2. RK5 PLUS VR Headset Headband Replacement: 步骤 2 中的图像 1,1
    • Remove the white headband adjustment part and carefully pull it off of the three straps.
  3. RK5 PLUS VR Headset Headband Replacement: 步骤 3 中的图像 1,3 RK5 PLUS VR Headset Headband Replacement: 步骤 3 中的图像 2,3 RK5 PLUS VR Headset Headband Replacement: 步骤 3 中的图像 3,3
    • To access the straps that need to be replaced, remove the padding around the visual lenses of the headset.
    • To do this, use your hands to detach the plastic frame between the padding and the lenses.
    • If you need help getting started, use a spudger or opening tool and undo the clips holding the plastic frame.
    • Unhook the old straps from the sides of the headset.
  4. RK5 PLUS VR Headset Headband Replacement: 步骤 4 中的图像 1,3 RK5 PLUS VR Headset Headband Replacement: 步骤 4 中的图像 2,3 RK5 PLUS VR Headset Headband Replacement: 步骤 4 中的图像 3,3
    • Reattach the new velcro straps to each of the white hooks.
    • Make sure the straps are securely attached to the hooks before moving on to the next step.
  5. RK5 PLUS VR Headset Headband Replacement: 步骤 5 中的图像 1,2 RK5 PLUS VR Headset Headband Replacement: 步骤 5 中的图像 2,2
    • Reattach the plastic frame with the padded back onto the headset.
    • Make sure the padding is properly aligned and clicked into place.
  6. RK5 PLUS VR Headset Headband Replacement: 步骤 6 中的图像 1,3 RK5 PLUS VR Headset Headband Replacement: 步骤 6 中的图像 2,3 RK5 PLUS VR Headset Headband Replacement: 步骤 6 中的图像 3,3
    • Reattach the top band into the top hook of the headset.
    • Take the other sides of the velcro straps and hook them into the white headband adjustment part.
    • Check that the straps are properly aligned and securely attached to the headband adjustment part.
  7. RK5 PLUS VR Headset Headband Replacement: 步骤 7 中的图像 1,1
    • You have successfully replaced your damaged headbands for the RK5 Plus VR headset!
结论
Faraaz Abdul
于01/30/23注册
145 声望
撰写一个指南
团队
York University, Team M-1, Allen Winter 2023 York University, Team M-1, Allen Winter 2023 的会员
YORK-ALLEN-W23SMG1
1 名成员
创作了1篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 4
过去 30 天: 15
总计 183
