跳转到主内容
修复你的物品
维修的权力
配件 & 工具
简介
This guide will show how to disassemble the Blackberry.
配件
没有特定配件。
  1. Remove the back cover exposing the battery, and remove the battery.
    • Remove the back cover exposing the battery, and remove the battery.
  2. Remove the six screws with the screwdriver using the T-5 tip.
    • Remove the six screws with the screwdriver using the T-5 tip.
  3. Pry open back cover
    • Pry open back cover
  4. Lift off the back cover.
    • Lift off the back cover.
  5. Unscrew the two screws with a T-6 screwdriver head
    • Unscrew the two screws with a T-6 screwdriver head
  6. Remove chip
    • Remove chip
  7. 任天堂 Switch 套装
    快速恢复到游戏的状态
    购买 Switch 套装
    任天堂 Switch 套装
    快速恢复到游戏的状态
    购买 Switch 套装
  8. Unscrew to remove the back plate
    • Unscrew to remove the back plate
  9. Carefully pry off back plate
    • Carefully pry off back plate
  10. Take off front cover and keypad
    • Take off front cover and keypad
  11. Remove one screw in the front.
    • Remove one screw in the front.
  12. Pry the two parts apart.
    • Pry the two parts apart.
  13. The screen is now apart from the phone.
    • The screen is now apart from the phone.
  14. Using the Philips screwdriver unscrew center screw.
    • Using the Philips screwdriver unscrew center screw.
  15. The final two parts now come apart.
    • The final two parts now come apart.
  16. The phone is now completely disassembled. Handle back with care shown piece comes right off.
    • The phone is now completely disassembled. Handle back with care shown piece comes right off.
  17. Your blackberry has been fully disassembled.
    • Your blackberry has been fully disassembled.
结论
另外一个人完成了本指南。
Laura Yanez
于2010年01月21日注册
2 信誉积分
撰写一个指南
团队
Cal Poly, Team 14-44, Regan Winter 2010 Cal Poly, Team 14-44, Regan Winter 2010 的会员
CPSU-REGAN-W10S14G44
4 名成员
创作了8篇指南
添加评论
浏览统计数据:
过去的24小时: 0
过去的7天: 0
过去的30天: 0
总计 2,739
