跳转到主内容
RIDGID R84015 X2 Planetary Gear Replacement Guide
你所需要的
  1. RIDGID R84015 X2 Planetary Gear Replacement Guide, RIDGID R84015 X2 Case Removal: 步骤 1 中的图像 1,2 RIDGID R84015 X2 Planetary Gear Replacement Guide, RIDGID R84015 X2 Case Removal: 步骤 1 中的图像 2,2
    • Remove the backplate.
    • Using a Torx T20 screwdriver, remove the four screws attaching the back plate.
  2. RIDGID R84015 X2 Planetary Gear Replacement Guide: 步骤 2 中的图像 1,1
    • Remove the drill handle.
    • Using the Phillips #2 screwdriver, remove the five screws attaching the drill handle to the body.
  3. RIDGID R84015 X2 Planetary Gear Replacement Guide: 步骤 3 中的图像 1,2 RIDGID R84015 X2 Planetary Gear Replacement Guide: 步骤 3 中的图像 2,2
    • Remove the gear casing from the body.
    • Using the Philips #2 screwdriver, remove the four screws attaching the gear casing to the body.
  4. RIDGID R84015 X2 Planetary Gear Replacement Guide, Planetary Gear: 步骤 4 中的图像 1,1
    • Prepare to remove the gear chamber.
    • Using the Phillips #2 screwdriver, unscrew the four screws at the rear of the plastic gear chamber.
  5. RIDGID R84015 X2 Planetary Gear Replacement Guide: 步骤 5 中的图像 1,2 RIDGID R84015 X2 Planetary Gear Replacement Guide: 步骤 5 中的图像 2,2
    • Remove the motor from the drill by gently pulling the motor away from the gear chamber.
    • NOTE: Handle the gear chamber with caution as the gears are now loose.
  6. RIDGID R84015 X2 Planetary Gear Replacement Guide: 步骤 6 中的图像 1,1
    • Remove the plastic gear chamber.
    • Using the Phillips #2 screwdriver, remove the four screws that attach the plastic gear chamber.
  7. RIDGID R84015 X2 Planetary Gear Replacement Guide: 步骤 7 中的图像 1,2 RIDGID R84015 X2 Planetary Gear Replacement Guide: 步骤 7 中的图像 2,2
    • Remove each component from the gear assembly. Replace components as needed.
    • Reassemble the drill following the gear replacement instructions in reverse order.
终点
4等其他人完成本指南。
Evan Long
于04/15/10注册
262 声望
创作了4篇指南
团队
Cal Poly, Team 15-48, Garner Spring 2010 Cal Poly, Team 15-48, Garner Spring 2010 的会员
CPSU-GARNER-S10S15G48
6 名成员
创作了10篇指南
一条评论
Very helpful, thank you! I was not sure how to detach the motor from the gearbox and didn't want to apply any brute force, and this explained it well.
YURIY - 回复
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 8
总计 6,217
