跳转到主内容
RIDGID R32104 Saw Blade Replacement
你所需要的
  1. RIDGID R32104 Saw Blade Replacement, Saw Blade: 步骤 1 中的图像 1,1
    • Turn off your saw and unplug before starting.
    • The RIDGID R32104 Saw did not come with a blade, so paper was used to mime the actions needed.
    • Place the Worm Drive Saw on a sturdy surface.
    • The blade is located within its upper blade guard and lower swing guard assembly.
  2. RIDGID R32104 Saw Blade Replacement: 步骤 2 中的图像 1,2 RIDGID R32104 Saw Blade Replacement: 步骤 2 中的图像 2,2
    • Using a H-6 mm Allen Key, remove the 3/8 - 16 UNC LH screw, washer, and outer blade washer that fixes the blade in place.
    • In order to unscrew this, you must turn the screw clockwise to loosen it.
  3. RIDGID R32104 Saw Blade Replacement: 步骤 3 中的图像 1,1
    • Adjust the lower swing guard to properly grab the blade.
  4. RIDGID R32104 Saw Blade Replacement: 步骤 4 中的图像 1,1
    • Remove the blade by gingerly grabbing towards its center, preventing any injury from occurring.
结论
另外一个人完成了本指南。
Lucas Pimentel
于04/02/19注册
1,010 声望
创作了8篇指南
团队
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 8
过去 30 天: 24
总计 1,102
