跳转到主内容
RIDGID R32104 Motor Bearings Replacement
你所需要的
  1. RIDGID R32104 Motor Bearings Replacement, Motor Brush: 步骤 1 中的图像 1,2 RIDGID R32104 Motor Bearings Replacement, Motor Brush: 步骤 1 中的图像 2,2
    • Turn off your saw and unplug before starting.
    • Place down the Worm Drive Saw on a sturdy surface.
    • The motor brush cap is located on the side of the main housing assembly, it can be identified as a large black plastic cap with a slit running down its surface.
  2. RIDGID R32104 Motor Bearings Replacement: 步骤 2 中的图像 1,2 RIDGID R32104 Motor Bearings Replacement: 步骤 2 中的图像 2,2
    • Using a flathead screwdriver, remove the motor brush cap from the main housing assembly.
  3. RIDGID R32104 Motor Bearings Replacement: 步骤 3 中的图像 1,1
    • With the cap removed, the motor brush should now be accessible.
    • Carefully remove the motor brush by sliding it out of the main housing assembly.
  4. RIDGID R32104 Motor Bearings Replacement, Upper Blade Guard Assembly: 步骤 4 中的图像 1,3 RIDGID R32104 Motor Bearings Replacement, Upper Blade Guard Assembly: 步骤 4 中的图像 2,3 RIDGID R32104 Motor Bearings Replacement, Upper Blade Guard Assembly: 步骤 4 中的图像 3,3
    • Maneuver the RIDGID saw, in order to easily remove the upper blade guard assembly.
    • Using the T20 Torx Screwdriver, remove the four 4/10 cm screws that attach to the gear box.
  5. RIDGID R32104 Motor Bearings Replacement: 步骤 5 中的图像 1,2 RIDGID R32104 Motor Bearings Replacement: 步骤 5 中的图像 2,2
    • Using the T50 Torx Screwdriver, remove the one 5/10 screw that attach to the gear box.
  6. RIDGID R32104 Motor Bearings Replacement: 步骤 6 中的图像 1,2 RIDGID R32104 Motor Bearings Replacement: 步骤 6 中的图像 2,2
    • Using the T20 Torx Screwdriver, remove the two 4/10 cm screws that attach to the handle of the device.
  7. RIDGID R32104 Motor Bearings Replacement: 步骤 7 中的图像 1,2 RIDGID R32104 Motor Bearings Replacement: 步骤 7 中的图像 2,2
    • Maneuver the saw to get to the base plate.
    • Using the T20 Torx Screwdriver, remove the two 4/10 cm screws that attach the upper blade guard’s base plate to the main housing assembly.
  8. RIDGID R32104 Motor Bearings Replacement, Main Housing Assembly: 步骤 8 中的图像 1,2 RIDGID R32104 Motor Bearings Replacement, Main Housing Assembly: 步骤 8 中的图像 2,2
    • Using the T20 Torx Screwdriver, remove the four 10 cm screws that attaches the main housing assembly to the gear box.
  9. RIDGID R32104 Motor Bearings Replacement, Gear Box: 步骤 9 中的图像 1,2 RIDGID R32104 Motor Bearings Replacement, Gear Box: 步骤 9 中的图像 2,2
    • Wiggle out the gear box to easily gain access to the motor rotor.
    • Once taken out, the motor rotor is easily accessible.
  10. RIDGID R32104 Motor Bearings Replacement, Motor Rotor: 步骤 10 中的图像 1,3 RIDGID R32104 Motor Bearings Replacement, Motor Rotor: 步骤 10 中的图像 2,3 RIDGID R32104 Motor Bearings Replacement, Motor Rotor: 步骤 10 中的图像 3,3
    • The motor rotor is lodged in between the armature and can be identified as a rod containing a fan blade.
    • Carefully remove the motor rotor from the device.
  11. RIDGID R32104 Motor Bearings Replacement, Motor Bearings: 步骤 11 中的图像 1,1
    • The bearings are located on the opposite end of the motor rotor, from where the fan blade was.
    • Carefully remove the motor bearings from the motor rotor.
结论
2等其他人完成本指南。
Lucas Pimentel
于04/02/19注册
1,010 声望
创作了8篇指南
团队
0条评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 1
过去 30 天: 3
总计 538
