跳转到主内容
RIDGID R2740 Motor Replacement
你所需要的
  1. RIDGID R2740 Motor Replacement, Motor: 步骤 1 中的图像 1,1
    • Orient the Ridgid Sander to where the Air Guard logo is facing upwards.
    • Unscrew the outlined screw in the figure with a Torx TR10 screw bit.
    • Remove the guard that is protecting the tread-line.
  2. RIDGID R2740 Motor Replacement: 步骤 2 中的图像 1,3 RIDGID R2740 Motor Replacement: 步骤 2 中的图像 2,3 RIDGID R2740 Motor Replacement: 步骤 2 中的图像 3,3
    • See attached diagram.
    • The guard below the wheels should be able to lift up out of place.
    • Remove the timing belt from the pulleys.
    • Unscrew the three screws with a Phillips #1 screwdriver.
    • Remove the large pulley after removing the screw.
    • Using the Torx TR10 Bit, unscrew the 10 screws which hold the external casing in place.
  3. RIDGID R2740 Motor Replacement: 步骤 3 中的图像 1,1
    • Remove the plastic housing by lifting it up from the device.
  4. RIDGID R2740 Motor Replacement: 步骤 4 中的图像 1,1
    • Flip the Ridgid Sander so that the Ridgid logo faces upwards.
    • The Ridgid Logo should be facing upwards.
  5. RIDGID R2740 Motor Replacement: 步骤 5 中的图像 1,3 RIDGID R2740 Motor Replacement: 步骤 5 中的图像 2,3 RIDGID R2740 Motor Replacement: 步骤 5 中的图像 3,3
    • Remove the brush caps from either side using a flathead screwdriver (See attached diagram).
    • Remove the plastic cover with the Ridgid logo.
    • Remove the brush assembly (See attached diagram).
  6. RIDGID R2740 Motor Replacement: 步骤 6 中的图像 1,2 RIDGID R2740 Motor Replacement: 步骤 6 中的图像 2,2
    • Now orient the Rigid Sander to the other side that shows the exposed motor.
    • The motor will be able to lift up out of place.
结论
0条评论
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 6
过去 30 天: 19
总计 640
