跳转到主内容
RIDGID R2740 Motherboard Replacement
你所需要的
  1. RIDGID R2740 Motherboard Replacement, Motherboard: 步骤 1 中的图像 1,1
    • Unplug your device before proceeding..
  2. RIDGID R2740 Motherboard Replacement: 步骤 2 中的图像 1,1
    • Orient the sander so the Air Guard logo is facing you.
    • Remove the single Torx TR20 screw.
  3. RIDGID R2740 Motherboard Replacement: 步骤 3 中的图像 1,2 RIDGID R2740 Motherboard Replacement: 步骤 3 中的图像 2,2
    • Orient the device with the left side face up.
    • Using a Phillips #1 bit, unscrew the 3 screws which hold the internal casing in place.
    • Gently remove the belt.
    • Using the Torx TR10 bit, unscrew the 10 screws which hold the external casing in place.
  4. RIDGID R2740 Motherboard Replacement: 步骤 4 中的图像 1,1
    • Gently pull up on the motherboard chip set, pulling it directly from the device.
结论
另外一个人完成了本指南。
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 11
总计 628
