跳转到主内容
RCX 1.0 Batteries Replacement
  1. RCX 1.0 Batteries Replacement, Batteries: 步骤 1 中的图像 1,1
    • Place the RCX on a flat surface.
  2. RCX 1.0 Batteries Replacement: 步骤 2 中的图像 1,1
    • Flip the RCX over so its black IR window is facing away from you.
  3. RCX 1.0 Batteries Replacement: 步骤 3 中的图像 1,1
    • Remove the gray battery cover by lifting from the front (near the IR window). Raise it at an angle and remove it to reveal the green battery compartment.
    • You can now remove the batteries and insert new ones.
结论
To reassemble your device, follow these instructions in reverse order. The orientation of the gray battery cover doesn't matter.
3等其他人完成本指南。
notexactly
于05/18/10注册
375 声望
创作了2篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 12
过去 30 天: 14
总计 2,639
