跳转到主内容
RCA Visys 25212 Handset Battery Replacement
你所需要的
  1. RCA Visys 25212 Handset Battery Replacement, Handset Battery: 步骤 1 中的图像 1,1
    • Place your thumb in the groove on the back of handset. Next, push down with your thumb and then slide the battery cover towards the bottom of the phone to remove the battery cover.
  2. RCA Visys 25212 Handset Battery Replacement: 步骤 2 中的图像 1,2 RCA Visys 25212 Handset Battery Replacement: 步骤 2 中的图像 2,2
    • To remove the battery, gently pull up on the white connector located on the left side of the phone.
结论
To reassemble your device, follow these instructions in reverse order. Make sure the battery connector is fully seated in the handset before replacing the back cover.
Sandy South
于01/26/15注册
431 声望
创作了4篇指南
团队
Pasco Hernando, Team 5-3, Prince Winter 2015 Pasco Hernando, Team 5-3, Prince Winter 2015 的会员
PHSC-PRINCE-W15S5G3
6 名成员
创作了8篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 2
过去 30 天: 3
总计 436
