跳转到主内容
RCA Visys 25212 Ear Piece Speaker Replacement
你所需要的
  1. RCA Visys 25212 Ear Piece Speaker Replacement, Handset Battery: 步骤 1 中的图像 1,1
    • Place your thumb in the groove on the back of handset. Next, push down with your thumb and then slide the battery cover towards the bottom of the phone to remove the battery cover.
  2. RCA Visys 25212 Ear Piece Speaker Replacement: 步骤 2 中的图像 1,2 RCA Visys 25212 Ear Piece Speaker Replacement: 步骤 2 中的图像 2,2
    • To remove the battery, gently pull up on the white connector located on the left side of the phone.
  3. RCA Visys 25212 Ear Piece Speaker Replacement, Handset: 步骤 3 中的图像 1,1
    • Remove the four screws, located at each of the corners within the back encasing, with a small Phillips head screwdriver.
  4. RCA Visys 25212 Ear Piece Speaker Replacement: 步骤 4 中的图像 1,2 RCA Visys 25212 Ear Piece Speaker Replacement: 步骤 4 中的图像 2,2
    • Insert a small flathead screwdriver between the face plate and the back of the handset.
    • Gently pry open the handset. You may need to insert the flathead screwdiver at multiple points in order to open the handset.
  5. RCA Visys 25212 Ear Piece Speaker Replacement: 步骤 5 中的图像 1,1
    • Using a small Phillips head screwdriver, remove the single screw (located at the top right) holding the circuit board in place.
  6. RCA Visys 25212 Ear Piece Speaker Replacement: 步骤 6 中的图像 1,2 RCA Visys 25212 Ear Piece Speaker Replacement: 步骤 6 中的图像 2,2
    • Lift up the circuit board to expose the keypad.
    • Be careful not to disconnect the two wires that connect the speaker to the circuit board.
    • Also, notice the two wires located at the bottom when lifting the circuit board, as these are apart of the charger.
  7. RCA Visys 25212 Ear Piece Speaker Replacement, Ear Piece Speaker: 步骤 7 中的图像 1,1
    • Gently lift out speaker using a small flathead screwdriver.
  8. RCA Visys 25212 Ear Piece Speaker Replacement: 步骤 8 中的图像 1,1
    • Set the speaker with the wires still attached on a flat surface. Place the tip of the soldering iron next to one of the leads until you are able to lift up the wire.
    • Repeat this process for the other lead.
    • Be sure you replace the wires at the same location on the new speaker.
结论
Sandy South
于01/26/15注册
431 声望
创作了4篇指南
团队
Pasco Hernando, Team 5-3, Prince Winter 2015 Pasco Hernando, Team 5-3, Prince Winter 2015 的会员
PHSC-PRINCE-W15S5G3
6 名成员
创作了8篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 5
总计 167
