简介
In order to replace the viewfinder on your RCA Small Wonders Camcorder CC176, it only takes a small flathead screwdriver, a safe place to keep the screws that you will take out of the camcorder, and a little bit of patience.
你所需要的
Remove the 5 screws that secure the control panel (located on the top of the device) by using your small flathead screwdriver.
Loosen the panel from the device until you are able to remove it.
即将完成!
结论
