跳转到主内容
RCA Small Wonders Camcorder CC176 Viewfinder Replacement
你所需要的
  1. RCA Small Wonders Camcorder CC176 Viewfinder Replacement, Viewfinder: 步骤 1 中的图像 1,3 RCA Small Wonders Camcorder CC176 Viewfinder Replacement, Viewfinder: 步骤 1 中的图像 2,3 RCA Small Wonders Camcorder CC176 Viewfinder Replacement, Viewfinder: 步骤 1 中的图像 3,3
    • Remove the 5 screws that secure the control panel (located on the top of the device) by using your small flathead screwdriver.
    • Loosen the panel from the device until you are able to remove it.
  2. RCA Small Wonders Camcorder CC176 Viewfinder Replacement: 步骤 2 中的图像 1,3 RCA Small Wonders Camcorder CC176 Viewfinder Replacement: 步骤 2 中的图像 2,3 RCA Small Wonders Camcorder CC176 Viewfinder Replacement: 步骤 2 中的图像 3,3
    • Remove the remaining 21 screws on the camcorder.
    • Begin separating the plastic casing from the inner components of the device.
  3. RCA Small Wonders Camcorder CC176 Viewfinder Replacement: 步骤 3 中的图像 1,2 RCA Small Wonders Camcorder CC176 Viewfinder Replacement: 步骤 3 中的图像 2,2
    • Grasping the viewfinder in hand, carefully remove the two screws that secure the mounting device.
    • Locate the gray electrical cord that connects the viewfinder to the inner components of the camera. Gently unplug the gray cord and loosen the viewfinder from the device.
    • Separate the viewfinder from the device and feed the gray cord through the hole in the plastic casing.
结论
Allison Baudoin
于12/05/11注册
401 声望
创作了4篇指南
团队
James Madison, Team 2-1, Allen Fall 2011 James Madison, Team 2-1, Allen Fall 2011 的会员
JMU-ALLEN-F11S2G1
2 名成员
创作了4篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 5
总计 1,272
