跳转到主内容
RCA Small Wonders Camcorder CC176 Speaker Replacement
你所需要的
  1. RCA Small Wonders Camcorder CC176 Speaker Replacement, Speaker: 步骤 1 中的图像 1,3 RCA Small Wonders Camcorder CC176 Speaker Replacement, Speaker: 步骤 1 中的图像 2,3 RCA Small Wonders Camcorder CC176 Speaker Replacement, Speaker: 步骤 1 中的图像 3,3
    • Remove the small black screws along the edges of the control panel on the top of the device.
    • Pry off the top control panel using the plastic wedge tool.
    • Remove the screw from the front, gray panel located beneath the "Scene Select AE" label.
    • Remove the two small black screws on the top of the front, gray panel of the device, above the red AUTOFOCUS letters.
  2. RCA Small Wonders Camcorder CC176 Speaker Replacement: 步骤 2 中的图像 1,1
    • Turn the device over and remove the two screws securing the front panel of the device.
    • Remove the screw securing the primary viewfinder, along the front of the camera.
    • Using a flat plastic tool, pry the entire front panel away from the device.
  3. RCA Small Wonders Camcorder CC176 Speaker Replacement: 步骤 3 中的图像 1,2 RCA Small Wonders Camcorder CC176 Speaker Replacement: 步骤 3 中的图像 2,2
    • Gently unplug the grey cord, located underneath the panel, disconnecting the speaker from the inner component of the device.
    • Remove the speaker from the device.
结论
Allison Baudoin
于12/05/11注册
401 声望
创作了4篇指南
团队
James Madison, Team 2-1, Allen Fall 2011 James Madison, Team 2-1, Allen Fall 2011 的会员
JMU-ALLEN-F11S2G1
2 名成员
创作了4篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 2
总计 906
