跳转到主内容
RCA RP3715A Motherboard Replacement
你所需要的
  1. RCA RP3715A Motherboard Replacement, Getting inside the device.: 步骤 1 中的图像 1,1
    • Take out the six screws located on the back of the device.
    • The red screws are 10 mm Phillip's #1. The orange screws are 13 mm Phillips #1.
    • Three screws are located on the back panel. One is located inside the battery carriage.
    • Two screws are located on the on the back panel on the bottom left and right side.
  2. RCA RP3715A Motherboard Replacement, Relieve extension cord tension.: 步骤 2 中的图像 1,3 RCA RP3715A Motherboard Replacement, Relieve extension cord tension.: 步骤 2 中的图像 2,3 RCA RP3715A Motherboard Replacement, Relieve extension cord tension.: 步骤 2 中的图像 3,3
    • Remove the 10 mm Phillip's #1 screw.
    • Then remove the metal reinforcement.
  3. RCA RP3715A Motherboard Replacement: 步骤 3 中的图像 1,2 RCA RP3715A Motherboard Replacement: 步骤 3 中的图像 2,2
    • Using flathead screwdriver undo the release tabs.
  4. RCA RP3715A Motherboard Replacement: 步骤 4 中的图像 1,3 RCA RP3715A Motherboard Replacement: 步骤 4 中的图像 2,3 RCA RP3715A Motherboard Replacement: 步骤 4 中的图像 3,3
    • Pry the release tabs with a spudger.
    • Start with back of the device on the topside.
  5. RCA RP3715A Motherboard Replacement: 步骤 5 中的图像 1,2 RCA RP3715A Motherboard Replacement: 步骤 5 中的图像 2,2
    • Pry open both tabs to remove the topside of the clock.
  6. RCA RP3715A Motherboard Replacement, Speaker Replacement: 步骤 6 中的图像 1,1
    • Remove the two 10mm Phillip's #1 screws. Also remove the two reinforcements holding the speaker in place.
  7. RCA RP3715A Motherboard Replacement, Detaching the front panel: 步骤 7 中的图像 1,1
    • Remove the two 10 mm Phillip's #1 screws.
  8. RCA RP3715A Motherboard Replacement: 步骤 8 中的图像 1,1
    • Remove the gray panel from the frame.
  9. RCA RP3715A Motherboard Replacement, Unlatch release tabs: 步骤 9 中的图像 1,3 RCA RP3715A Motherboard Replacement, Unlatch release tabs: 步骤 9 中的图像 2,3 RCA RP3715A Motherboard Replacement, Unlatch release tabs: 步骤 9 中的图像 3,3
    • The two latches located in the picture will help take off the display.
    • Remove the display.
  10. RCA RP3715A Motherboard Replacement, Motherboard: 步骤 10 中的图像 1,2 RCA RP3715A Motherboard Replacement, Motherboard: 步骤 10 中的图像 2,2
    • asd
  11. RCA RP3715A Motherboard Replacement, Removing the top part of motherboard: 步骤 11 中的图像 1,1
    • Remove the top 5 10mm Phillips #1 screws holding the top part of the motherboard
  12. RCA RP3715A Motherboard Replacement, Removing the side part of motherboard: 步骤 12 中的图像 1,1
    • Remove the 5 10mm Phillip's #1 screws that holding side part of the motherboard
  13. RCA RP3715A Motherboard Replacement: 步骤 13 中的图像 1,1
    • Remove the transformer by pulling back the release tab shown.
  14. RCA RP3715A Motherboard Replacement: 步骤 14 中的图像 1,1
    • Pull the battery terminal through the whole shown.
  15. RCA RP3715A Motherboard Replacement, Lift the digital screen: 步骤 15 中的图像 1,1
    • First release the latch highlighted in the picture. Then grab the screen by the bottom and lift it up.
  16. RCA RP3715A Motherboard Replacement, Lift the top piece of motherboard: 步骤 16 中的图像 1,3 RCA RP3715A Motherboard Replacement, Lift the top piece of motherboard: 步骤 16 中的图像 2,3 RCA RP3715A Motherboard Replacement, Lift the top piece of motherboard: 步骤 16 中的图像 3,3
    • Remove the motherboard from the frame using the illustration shown.
结论
另外一个人完成了本指南。
团队
USF Tampa, Team 10-5, Brown Fall 2014 USF Tampa, Team 10-5, Brown Fall 2014 的会员
USFT-BROWN-F14S10G5
3 名成员
创作了5篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 6
过去 30 天: 12
总计 557
