跳转到主内容
修复你的物品
维修的权力
配件 & 工具
简介
If the power button is unresponsive, broken, or otherwise damaged, it may be time to replace the power button on your RCA tablet. This replacement guide will teach you how to properly open your device, remove the broken power button, and replace it with a new one.
  1. Remove two 2.4mm x 4mm screws from bottom of the tablet with Phillips #00 Screwdriver. Remove two 2.4mm x 4mm screws from bottom of the tablet with Phillips #00 Screwdriver.
    • Remove two 2.4mm x 4mm screws from bottom of the tablet with Phillips #00 Screwdriver.
  2. 任天堂 Switch 套装
    快速恢复到游戏的状态
    购买 Switch 套装
    任天堂 Switch 套装
    快速恢复到游戏的状态
    购买 Switch 套装
  3. Remove back cover with plastic opening tool, exposing the battery and motherboard. Remove back cover with plastic opening tool, exposing the battery and motherboard.
    • Remove back cover with plastic opening tool, exposing the battery and motherboard.
  4. Insert the power button into the button slot with the tweezers. Insert the power button into the button slot with the tweezers.
    • Insert the power button into the button slot with the tweezers.
结论
2等其他人完成本指南。
John Sudduth
于2015年03月26日注册
79 信誉积分
撰写一个指南
团队
Clemson, Team 14-4, Shirley Spring 2015 Clemson, Team 14-4, Shirley Spring 2015 的会员
CLEM-SHIRLEY-S15S14G4
6 名成员
创作了15篇指南
添加评论
浏览统计数据:
过去的24小时: 0
过去的7天: 0
过去的30天: 0
总计 2,055
