跳转到主内容
RCA RCT6378W2 Battery Replacement
你所需要的
  1. RCA RCT6378W2 Battery Replacement, Battery: 步骤 1 中的图像 1,3 RCA RCT6378W2 Battery Replacement, Battery: 步骤 1 中的图像 2,3 RCA RCT6378W2 Battery Replacement, Battery: 步骤 1 中的图像 3,3
    • Remove the two 2.4 mm x 4 mm Phillips #00 screws from the bottom of the tablet.
  2. RCA RCT6378W2 Battery Replacement: 步骤 2 中的图像 1,3 RCA RCT6378W2 Battery Replacement: 步骤 2 中的图像 2,3 RCA RCT6378W2 Battery Replacement: 步骤 2 中的图像 3,3
    • Remove the back cover with a plastic opening tool, exposing the battery and motherboard.
  3. RCA RCT6378W2 Battery Replacement: 步骤 3 中的图像 1,3 RCA RCT6378W2 Battery Replacement: 步骤 3 中的图像 2,3 RCA RCT6378W2 Battery Replacement: 步骤 3 中的图像 3,3
    • Remove the two black tape strips from the battery pack.
  4. RCA RCT6378W2 Battery Replacement: 步骤 4 中的图像 1,3 RCA RCT6378W2 Battery Replacement: 步骤 4 中的图像 2,3 RCA RCT6378W2 Battery Replacement: 步骤 4 中的图像 3,3
    • Remove the battery pack by carefully prying the battery back from the front cover. Then, remove the wires connecting the battery to the motherboard at the motherboard using the tweezers.
  5. RCA RCT6378W2 Battery Replacement: 步骤 5 中的图像 1,1
    • Replace the damaged or malfunctioning battery with the new battery and wires. The new battery must be stuck back into its original place using thermal tape.
  6. RCA RCT6378W2 Battery Replacement: 步骤 6 中的图像 1,3 RCA RCT6378W2 Battery Replacement: 步骤 6 中的图像 2,3 RCA RCT6378W2 Battery Replacement: 步骤 6 中的图像 3,3
    • The new wires must be soldered back into place on the motherboard at the original location.
    • For tips on soldering techniques, see this Soldering Guide.
结论
12等其他人完成本指南。
Justin
于01/29/15注册
425 声望
创作了2篇指南
团队
Clemson, Team 14-4, Shirley Spring 2015 Clemson, Team 14-4, Shirley Spring 2015 的会员
CLEM-SHIRLEY-S15S14G4
6 名成员
创作了15篇指南
7条评论
Links on ordering replacement batteries
Great step by step instructions not for novices!
Robert Groffel - 回复
Can you give information about this battery?
What type of battery is it?
Is Applicable under the Dangerous Goods Regulations?
carlos - 回复
where do i order the battery for RCT6378W2
Michael Giulian - 回复
RCT6378W2 where can i get a replacement battery
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 24
过去 30 天: 95
总计 26,311
