跳转到主内容
RCA RCT6203W46 Rear Speaker Replacement
你所需要的
  1. RCA RCT6203W46 Rear Speaker Replacement, Rear Speaker: 步骤 1 中的图像 1,2 RCA RCT6203W46 Rear Speaker Replacement, Rear Speaker: 步骤 1 中的图像 2,2
    • Remove these four 4 mm Phillips #00 screws.
  2. RCA RCT6203W46 Rear Speaker Replacement: 步骤 2 中的图像 1,2 RCA RCT6203W46 Rear Speaker Replacement: 步骤 2 中的图像 2,2
    • Run a spudger tool around the edge of the screen to loosen it and begin to pry upward.
    • The screen will be able to be removed once you see it pop up like it has in the photo.
    • There are wires attached to the back cover and screen so be careful not to pull them apart.
  3. RCA RCT6203W46 Rear Speaker Replacement: 步骤 3 中的图像 1,3 RCA RCT6203W46 Rear Speaker Replacement: 步骤 3 中的图像 2,3 RCA RCT6203W46 Rear Speaker Replacement: 步骤 3 中的图像 3,3
    • With a soldering iron, remove the wires from the circuit board.
    • Due to the size of the wires, tweezers may be necessary.
  4. RCA RCT6203W46 Rear Speaker Replacement: 步骤 4 中的图像 1,1
    • Use a metal spudger to pry out the speakers from its housing.
结论
3等其他人完成本指南。
团队
UC Davis, Team 1-2, Oliver Fall 2016 UC Davis, Team 1-2, Oliver Fall 2016 的会员
UCD-OLIVER-F16S1G2
5 名成员
创作了4篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 2
总计 323
