跳转到主内容
RCA RCT6203W46 Battery Replacement
你所需要的
  1. RCA RCT6203W46 Battery Replacement, Battery: 步骤 1 中的图像 1,2 RCA RCT6203W46 Battery Replacement, Battery: 步骤 1 中的图像 2,2
    • Make sure the device is off to reduce the chance of an electrical shock. To turn off the device, press and hold the power button.
    • Use a Phillips #00 Screwdriver to unscrew the 4mm (5/32 in.) screws from the back cover of the tablet.
  2. RCA RCT6203W46 Battery Replacement: 步骤 2 中的图像 1,2 RCA RCT6203W46 Battery Replacement: 步骤 2 中的图像 2,2
    • Use a spudger to pry the back cover. Start from one edge of the back cover and slide across until the cover is lifted from the tablet body. Repeat for all edges.
  3. RCA RCT6203W46 Battery Replacement: 步骤 3 中的图像 1,1
    • Open the tablet cover carefully and slowly lengthwise.
    • The keyboard wire ribbon and rear speaker wire should be intact and connected with the back cover.
    • Opening the tablet abruptly may tear or damage cover attachments.
  4. RCA RCT6203W46 Battery Replacement: 步骤 4 中的图像 1,2 RCA RCT6203W46 Battery Replacement: 步骤 4 中的图像 2,2
    • Use a spudger to flip up the flap of the ZIF connector that holds the keyboard wire ribbon.
    • Remove the wire ribbon from clamp.
  5. RCA RCT6203W46 Battery Replacement: 步骤 5 中的图像 1,2 RCA RCT6203W46 Battery Replacement: 步骤 5 中的图像 2,2
    • Use a soldering iron to melt the solder then remove the red and black wire from the motherboard.
  6. RCA RCT6203W46 Battery Replacement: 步骤 6 中的图像 1,1
    • Use a spudger to pry and slide underneath the battery to unstick it from the LCD metal plate. It may take a good amount of force to remove.
    • Try to decrease battery deformation by using a spudger rather than prying with your hands.
    • Do not let battery fall back on adhesive, it will stick back onto the LCD metal plate.
    • Be careful to not puncture the battery. The battery may ignite or explode.
结论
8等其他人完成本指南。
团队
UC Davis, Team 1-2, Oliver Fall 2016 UC Davis, Team 1-2, Oliver Fall 2016 的会员
UCD-OLIVER-F16S1G2
5 名成员
创作了4篇指南
3条评论
If the battery is bad and the device is plugged in, should it power up or does the battery need to be in good order to power on? Pressing the power button produces a icon outline of a battery with a triangle and asterisk inside it.
John - 回复
My tablet is doing a strange thing. I powers up then initializes and when it gets to where it says voyager it just stays there indefinately. Occasionally it will complete initalizing then will work for a while then go back to voyager and not work. Is there anything I can do to fix it?
Gerald Couvillion - 回复
It seems to me that when we got these new they had to charge up for a while before they would “boot” (work) at all. So it stands to reason that if one has a “flaky” battery it might do that. I think that’s what my 7” RCA did when it died. From the 10’ manual, it says,
“Do not wait for the battery to be fully depleted before charging again. Keep the battery charged as needed. If tablet has not been used for a long period of time, the battery might be in over discharge protection mode and may take longer to charge.”
So a flaky battery may put the tablet in the “over discharge protection mode”, meaning it is “cut off” & won’t work.
Gotta ask: where is everyone learning to spell “definitely” as “definately”? Here’s a help to remember: the root word is “finite”, not “finate”.
Good luck with your tablet!
ImJusThinkin -
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 6
过去 30 天: 29
总计 14,180
