跳转到主内容
RCA RCT6077W2 Backplate Replacement
你所需要的
  1. RCA RCT6077W2 Backplate Replacement, Backplate: 步骤 1 中的图像 1,2 RCA RCT6077W2 Backplate Replacement, Backplate: 步骤 1 中的图像 2,2
    • Remove the two 2.5mm Phillips head screws before attempting to remove the screen from the device.
  2. RCA RCT6077W2 Backplate Replacement: 步骤 2 中的图像 1,2 RCA RCT6077W2 Backplate Replacement: 步骤 2 中的图像 2,2
    • Run an opening pick around the edge of the screen to loosen it and begin to pry upward.
    • When the screen comes up like it has in the photo, it should be able to simply be removed from its casing.
    • The buttons on the end of the device will be loose when you remove the screen from the backplate. Be careful not to lose them.
结论
3等其他人完成本指南。
Ryan Williams
于01/27/15注册
1,157 声望
创作了4篇指南
团队
Pasco Hernando, Team 1-2, Prince Winter 2015 Pasco Hernando, Team 1-2, Prince Winter 2015 的会员
PHSC-PRINCE-W15S1G2
6 名成员
创作了8篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 9
总计 1,333
