简介
This guide will focus on replacing the speakers on the RCA RCR8622 in a step by step manner.
配件
无需配件。
  1. Remove the casing. Slide the plastic cover with the graphic off the main base. Be careful and hold both sides.
    • Remove the casing. Slide the plastic cover with the graphic off the main base. Be careful and hold both sides.
    • Flip the device over and unscrew the five 11 mm screws with a Phillip's #1 screwdriver.
      • A magnetic screwdriver will help you remove the screws from their slots.
  2. Pull the top of the device off and look closely at the motherboard. You will see two speakers, one on each side of the device.
    • Pull the top of the device off and look closely at the motherboard. You will see two speakers, one on each side of the device.
    • Grab the tweezers and follow the red and black wires leading from the speaker to the motherboard. They will attach to a white casing. Lift the white plug out with the tweezers to disconnect.
    • Grab the speaker and pull upward. The Speakers will be loose.
      • Repeat this step with the other speaker.
结论
Josh Excell
于2018年03月20日注册
449 信誉积分
创作了4篇指南
团队
IUPUI, Team S6-G5, Baechle Spring 2018 IUPUI, Team S6-G5, Baechle Spring 2018 的会员
IUPUI-BAECHLE-S18S6G5
3 名成员
创作了4篇指南
浏览统计数据:
过去的24小时: 0
过去的7天: 0
过去的30天: 3
总计 60
