跳转到主内容
RCA RCR8622 LCD Screen Replacement
你所需要的
  1. RCA RCR8622 LCD Screen Replacement, Speaker: 步骤 1 中的图像 1,3 RCA RCR8622 LCD Screen Replacement, Speaker: 步骤 1 中的图像 2,3 RCA RCR8622 LCD Screen Replacement, Speaker: 步骤 1 中的图像 3,3
    • Remove the casing. Slide the plastic cover with the graphic off the main base. Be careful and hold both sides.
    • Flip the device over and unscrew the five 11 mm screws with a Phillip's #1 screwdriver.
    • A magnetic screwdriver will help you remove the screws from their slots.
  2. RCA RCR8622 LCD Screen Replacement: 步骤 2 中的图像 1,3 RCA RCR8622 LCD Screen Replacement: 步骤 2 中的图像 2,3 RCA RCR8622 LCD Screen Replacement: 步骤 2 中的图像 3,3
    在这个步骤中使用的工具:
    • Pull the top of the device off and look closely at the motherboard. You will see two speakers, one on each side of the device.
    • Grab the tweezers and follow the red and black wires leading from the speaker to the motherboard. They will attach to a white casing. Lift the white plug out with the tweezers to disconnect.
  3. RCA RCR8622 LCD Screen Replacement: 步骤 3 中的图像 1,2 RCA RCR8622 LCD Screen Replacement: 步骤 3 中的图像 2,2
    • Grab the speaker and pull upward. The Speakers will be loose.
    • Repeat this step with the other speaker.
  4. RCA RCR8622 LCD Screen Replacement, LCD Screen: 步骤 4 中的图像 1,3 RCA RCR8622 LCD Screen Replacement, LCD Screen: 步骤 4 中的图像 2,3 RCA RCR8622 LCD Screen Replacement, LCD Screen: 步骤 4 中的图像 3,3
    • Remove the two 11mm screws from the motherboard with the Phillip's #1 screwdriver.
    • Squeeze the 2 metal prongs on the interior of the motherboard inward until a clicking noise is heard.
  5. RCA RCR8622 LCD Screen Replacement: 步骤 5 中的图像 1,3 RCA RCR8622 LCD Screen Replacement: 步骤 5 中的图像 2,3 RCA RCR8622 LCD Screen Replacement: 步骤 5 中的图像 3,3
    • Lift the motherboard out of the interior of the device.
    • Remove the screen section of the device by lifting upward on the circuit it is connected to by sliding it upwards.
    • Both sections will be connected with a ribbon connection.
  6. RCA RCR8622 LCD Screen Replacement: 步骤 6 中的图像 1,3 RCA RCR8622 LCD Screen Replacement: 步骤 6 中的图像 2,3 RCA RCR8622 LCD Screen Replacement: 步骤 6 中的图像 3,3
    • Flip both components of the circuitry over and from the main motherboard you will see metal pins that lead to the LCD screen.
    • Heat the solder around the pins with a soldering iron so the pins can be removed and the screen can be detached. Use a flat object to help push out the pins.
  7. RCA RCR8622 LCD Screen Replacement: 步骤 7 中的图像 1,2 RCA RCR8622 LCD Screen Replacement: 步骤 7 中的图像 2,2
    • Lift the screen upward, taking care not to allow the films below it to fall out.
结论
Josh Excell
于03/20/18注册
449 声望
创作了4篇指南
团队
IUPUI, Team S6-G5, Baechle Spring 2018 IUPUI, Team S6-G5, Baechle Spring 2018 的会员
IUPUI-BAECHLE-S18S6G5
3 名成员
创作了4篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 4
过去 30 天: 12
总计 313
